Getting a code need alittle advice
Old Apr 23, 2005 | 09:01 PM
BadMonkey's Avatar
BadMonkey
Default Getting a code need alittle advice
I posted this in teh Tune section as well. But thought I would ask some of you as well to see what you all think. I know I need a better tune but that is coming after my headers. I been getting this code for the better part of a year now P H 0327 Knock Sensor Low Frequency. I just replaced the sensors and the wire harness under the intake. Have you guys got this as well? Help em out here please. I reset it and it goes away for a while then comes back after about 10-20 miles sometimes longer. Thats gettting on it or just cruising weither way. Sometimes I reset it sometimes it gets recycled but comes back later. Funny thing is I been getting this code over a year now and over 18000 miles. Since I been running it and not getting any feel or sound of knocking I am jsut lost especially since it still runs like an ape. I run 93 Octane here in Kentucky.
Damon
Old Apr 24, 2005 | 02:45 AM
MelloYellow's Avatar
MelloYellow
Same issue.
You can check and clear it on the DIC. Doesn't happen too often.
Which intake do you have?
If an LS6 style you want to dremel the ribs underneath to create a valley so as to not pinch the KS wires.
Other than that, check the PCM wires for the KS harness for corrosion.
Has your PCM ever been programmed or is it stock?
Old Apr 24, 2005 | 07:19 AM
BadMonkey's Avatar
BadMonkey
its programmed for the ATI. I checked the wires under the intake (ls1 and its not hitting anymore. Guess I nee to check from teh plug to the computer.
To Getting a code need alittle advice
