Boost a pump install question
Old Apr 29, 2005 | 10:41 PM
XotiK ZO6's Avatar
XotiK ZO6
Default Boost a pump install, Help!!
Does anyone have, or can explain the "boost a pump" connections?? The instructions that came with it are lacking to say the least . I really need wire colors and locations to splice the boost a pump into on an 03 Z.
Thank you to anyone who can respond. Yes, I tried the search function and nothing remotely close was found.
Old Apr 30, 2005 | 12:30 PM
3XBlack6spd's Avatar
3XBlack6spd
If you don't have any luck I can fax them to you on Monday.....i am assuming this a Kenne Bell?
Old Apr 30, 2005 | 06:10 PM
Dr. Dan's Avatar
Dr. Dan
Here's what I got from LPE when I did mine last winter.
Find Connector 140 Pin C Gray wire. This gets Red fused wire from BAP.
On inner fender beside battery has light green tape around wire bundle. After the connector (towards rear of car) Cut gray wire, the larger of the two. This gets the unfused red wire from BAP.
Cut off controller and solder wires together. This will run the BAP at 100% when the boost pressure switch opens.
Boost pressure switch wires do not matter which post goes to which wire.
Black BAP wire to ground.
Hope this helps,
Dan
Old May 2, 2005 | 09:53 AM
XotiK ZO6's Avatar
XotiK ZO6
Hope this helps,
Dan
3XBlack I will probably PM you for the Fax.
I will take a look tonight with your discription Dr...
Thanks!!
Anyone else?
To Boost a pump install question
