Please post up pics of your installed nitrous switch configs. I'm running a home made set of switches right now but really want something that looks much better. TIA
This is a older home made sw panel. My new set-up has purge where the lighter goes and a 2nd stage micro toggle and light above that. Also has 2 rpm indicator lights for when each stage activates. shut ash tray and see nothing, also everything can be put back to stock. Will post new pic into my web soon.
No that's home made, it's aluiminum, with removable screws for wiring schemes in future. A lot of aftermarket panels use double stick tape. Here's a pic (in web about #35) with new wiring scheme, additional toggle purge to lighter and three lights and first gear lock out, a lot of wiring but fits fine. You have to trim aluim brkt in console. Will ad new pic of new sw set-up soon.
I have like a million wires behind NX switch. I also have swititchs for 20 strobes, backup camera, purge, and arming button.
Heres a pic, not the greatest but you can see it.
Jon
Heres my NX switch panel, fits fine but I trimmed out the back of the ashtray to be able to get at all the wires. Have since put in a weathpack connector to be able to unplug the whole switch with one plug.
