Same boost, more grip, more power???
Old Jun 3, 2005 | 04:05 AM
blu00rdstr's Avatar
blu00rdstr
Default Same boost, more grip, more power???
I had an odd experience. I installed the A&A bracket setup with 8-rib pulleys. I messed up at first and drove with a loose belt, and ended up with a 6-rib belt (belt jumped and two ribs got ate). Then I got the tension 'close' (tensioner at 2/3) with a larger idler pulley from Andy, and an alternator spacer from Diynoob, and maxed at 10-11psi, but not much more SOTP power than with a 6-rib setup. I couldn't find the belt I needed and didn't think 6-1/2 rib would make that much difference.
Finally got a new 8-rib belt (Auto Zone Kelly-Springfield 897K8), and put the alternator spacer on the bottom of the alternator instead of the top (big difference). Now with the proper belt and tension (tensioner at 1/3), I have 10-12psi (close to the same boost), but noticed a big increase in SOTP power. Haven't had it tuned yet, it seems to be running rich due to the new headers. But the car is much 'jumpier', and I get tirespin at will.
What's up with the same boost but more power with better belt grip?
Old Jun 3, 2005 | 10:17 AM
ramcharger's Avatar
ramcharger
if your belt is slipping less your boost is building more quickly, thus giving you more of an impulse addition of torque. makes sense to me.
Old Jun 3, 2005 | 07:42 PM
blu00rdstr's Avatar
blu00rdstr
Thanks!
I wish there was a better way to measure 'boost' than psi. I guess there really is such a thing as 'belt lag'.
Old Jun 4, 2005 | 12:38 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Hey Blu,
Nice to see your system is going forward for you. When I had mine set-up at 16#'s it seemed as though it was running on an extremely sharp edge--it was just jumping at the slightest throttle input. My greedy side loved it but the practical side stepped up.
Now that you've installed the 8 rib I think that you've finally eliminated the initial belt slip and probably increased your torque also. So, how are you going to deal with the new loss of traction issue?
Old Jun 4, 2005 | 07:46 PM
blu00rdstr's Avatar
blu00rdstr
Originally Posted by xtream1
Hey Blu,
Hey xtream1, good to hear from you. Hopefully you'll be at A&A on the 11th.
I still have the Nitto 305DRs on, and someone told me it's not wise to have rear tires stickier than the fronts, so I just put Nitto RIIs up front. Today I'm moving the MAF against the throttle body, and moving the BOV to the upper pipe where I can keep an eye on it and maybe a muffler (oil breather). I also hope to be at Vette Magic in Sacramento tomorrow, at least if things go smoother than they have been today. I'm sure Andy will just smile at my work and encourage me to buy his professionally made products.
To Same boost, more grip, more power???
