Need help !!
Old Jun 3, 2005 | 10:01 PM
Ozi's Avatar
Ozi
Default Need help !!
Magna charged vette now running bad. Has less than 30K miles. Pulled sparks plugs, did compression test and both sides appear the same, but one side spark plugs look good, other side look bad. Runs but doesn't idle very good. Gets worse as the car warms up. Definate loss of power, but still runs. Put on cruise control at 45mph and it surges. Can't tell if its gas, air or electrical ... help ???
Old Jun 3, 2005 | 10:23 PM
blu00rdstr's Avatar
blu00rdstr
Any codes? Is it a pair of cylinders or all four? Did you check for O2 codes or the connector to the coilpack?
