Alky questions
Old Jun 13, 2005 | 07:14 PM
2fast4sanity's Avatar
2fast4sanity
Default Alky questions
I have a few questions about alky/methanol injection. I've heard that you can smell it while driving. How strong is the smell? Also, on average, how long would a tank of alky last? (typical WW reservoir setup) Does it last longer than a tank of gas? I just keep thinking that it might end up being a hassle, sort of like filling a nitrous bottle all the time. If you run out, does it mess up your tune since your no longer spraying it? How easy is it to buy methanol and what does it cost? Probably all dumb questions, but thanks in advance.
Old Jun 13, 2005 | 07:30 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
One WW tank full will generally last for two tanks of gas depending on how heavy your foot is. There is no smell inside the vehicle that I have ever noticed.
If your car is aggresivly tuned due to the alky then if you run out you would need to stay out of boost untill it is refilled.
It is alot easier than filling nos because you do not need a fill station etc, it is the same as filling washer fluid.
Methanol is about $3 dollars per gal at the track.
Or order it from VP fuels.
Old Jun 13, 2005 | 09:10 PM
BlackMagicC5's Avatar
BlackMagicC5
Or you can just use denatured alcohol. Very conveinent to buy. Just swing by home depot and pick up a bottle whenever necessary.
Old Jun 15, 2005 | 04:41 AM
Robiwan's Avatar
Robiwan
I have Julio's kit, using WW tank and I have never smelled methanol. I get about 2 tanks of gas to one tank of methanol inWW. I looked up auto racing in the phonebook, asked them where to buy and found a local shop within 15 minutes. Bought a new 5 gal gas can just for meth and I'm set. I live in Boulder Co, and thought I would have to order, but no. Might try phonebook and do a little calling, might get surprised.
Old Jun 15, 2005 | 06:38 AM
tici's Avatar
tici
Tune: alcohol affects the WB reading (it gets richer).
I would first spray water alone, set the AFR, and then switch to water-alcohol.
Also be careful to spray only during PE or the LTFT (+ STFT) will be messed up big time (-10 or so) during a certain time (1-2 minutes).
Old Jun 15, 2005 | 05:29 PM
2fast4sanity
I followed you until the last sentence, can someone enlighten me as to the abbreviations?
Old Jun 16, 2005 | 04:02 AM
tici's Avatar
tici
PE = power enrichment = cell 22 = WOT = no reading the O2's to correct fueling
STFT = short term fuel trims
LTFT = long term fuel trims
O2 = oxygen sensor = lambda sensor
If the car is not in PE the O2's will tell the PCM to correct fueling to stay stoichiometric.
STFT change instantanely, LTFT change within longer time (minutes?). It belong to the learning (adaptive) system of the PCM.
If you spray alcohol during this learning process the PCM will reduce the fuel because it thinks the AFR is off (too rich).
If you spray during PE the PCM won't care.
Old Jun 16, 2005 | 02:51 PM
Harley99's Avatar
Harley99
I cant smell anything as of yet... I get 2 to 3 tanks of gas per 1 gallon of Meth...
Old Jun 16, 2005 | 03:38 PM
tici's Avatar
tici
Harley99, could you pls tell me your WI settings? Just curious to know what other people are running.
I use 50% ethanol, 5GPH @ 100 PSI, start to inject @ 2 PSI.
My AFR (spraying water alone) is set @ 12.5 and WOT timing is 17*. I saw no power increase with more timing or different AFR so I guess it's optimized. I just can't compare it with others because not many people run the same setup (6PSI Vortech non intercooled).
Old Jun 18, 2005 | 04:26 AM
Julio's Avatar
Julio
The alcohol that smells is Denatured. Methanol burns completely odorless. Denatured smells like antifreeze poured on a header.. like a sweet pungent smell..
HTH
Old Jun 18, 2005 | 08:49 AM
c52k1vert's Avatar
c52k1vert
916/795 rwhp C5R 412 YSI
HTH
Now that I'm on alky, after a Dyno pull everyone has to go outside and wipe their eyes. The meth really stings... Not as bad as a car running straight Race Gas, but getting close.
I find that every degree of timing I add, I pick up 5 RWHP @ 12 PSI. Since I have a stock bottom I really did not try to push it too far, but did verify it was acting linear with the last 4 degrees of timing I added up to 21. (Your mileage may vary)
Old Jun 20, 2005 | 09:09 PM
dads01dream's Avatar
dads01dream
Holy cow!!! You're making that kind of hp with a stock bottom-end & 12psi. Man, you're a brave guy. That must be some kinda tune you've got on that car.
Old Jun 20, 2005 | 09:21 PM
c52k1vert's Avatar
c52k1vert
Yeah... It is a bit ballsy I'll admit. But the worst thing that can happen is I have to install a forged motor and do it right. It has been a bit of an experiment to be honest. I really have wanted to see just how far stock heads and stock bottom could take me. Jeff @ Carolina Auto Masters really is one of the best tuners.
I'm really surprised that I'm able to pull down that kind of power, I guess with a t-trim, alky, cam, etc I guess I finally have done enough to get there. A decent set of heads would certainly be too much for it I'm sure.
Old Jun 20, 2005 | 09:39 PM
dads01dream
Well..... no way of knowing without trying!!! Go on and git those extra parts, I'd love to find out where the "limit" ultimately is.
Kudos to your tuner, the guy's obviously got a great little system going there. Have you ever taken it to the track? Just curious how your car runs.
Old Jun 20, 2005 | 09:54 PM
c52k1vert's Avatar
c52k1vert
I have only been to the strip once when I had 523 rwhp. I really did not know how to launch properly using a linelock and after 6 runs toasted my clutch dumping around 3500 rpm. I've trashed 2 McCloud twin streets with Kevlar and now I'm on a dual disk Exedy.
My problems then and somewhat still exist today is 4.10's (too much gear), too big profile of tire 18" and I need to drop to a 16" or 17", drag radials when I need to get something that I don't spin 25% of the way up the track. Yada yada. Also I had a rev limiter set at 6200 RPM then, so I was going through the traps under no power or having to shift into 5th. Now, I'm set @ 6800 RPM, so it is a bit better. Still need 3.42's and some M/T's before I try again.
I actually ran a 11.82 @ 118 MPH, which I was disappointed in. 1.79 60' time and 97.9 MPH 1/8th.
Old Jun 20, 2005 | 11:01 PM
dads01dream
Huh..... only 118 mph? Sure sounds like you were maxed out on gear! Well, I guess it's true what they say..... It's all in the *combination*.
Hearing about clutch issues always makes me glad I have an A4, a weak/stock A4, but at leat I can get a performance rebuild to avoid any future problems.
Thanks again.
To Alky questions
