nitros bag kit
Old Jun 14, 2005 | 04:07 PM
DSCHULTZ's Avatar
DSCHULTZ
Default nitros bag kit
Has Anyone Tried One On C 5 Should I go With This Or Buy Complete Set Up. Bag Kit Is A Kit Were You Put The Nozzle In Right After Air Filter.
Old Jun 15, 2005 | 06:08 PM
aggie_corvette's Avatar
aggie_corvette
i have the "bottle in a bag", although i haven't used on my c5 (full wet install).
I have used it on several cars. basically its a dry kit, w/shots about 25/50/75/100. If you've ever used n2o before you can make the kit.
bottle, fitting, purge soloniod, "jet", really long nylon tube. Then simply make a cigerate lighter adapter with a push button to activate.
The fun part is you can install it in about 10 min in any car and it fits in a duffle bag.
Will it blow up the engine.... yes and no. put to much n2o in and it will blow it. stay reasonable and you can run it all day.
You can stick it infront or after the airfilter. Just make sure its before the MAF.
