ECS Resolves My TTix Problem
Jun 24, 2005 | 10:35 PM
St. Jude Donor '03 through '17
I thought I was having a tunning issue with my build due to a tunning issue with ECS.
ME BAD!!!!!!!!!!!!
My car @ 4,000 Rpms seem to hit a wall which I thought was a problem with the tune as I said.
Well it turns out that when I was driving the car with the A/H control on it was retarding and adding fuel.
It was a real quick fix as Chris, Doug and myself took the car out with the A/H off and used my data log to road tune the car.
Well there was no need what so ever to re tune being my afr from 1st -6th was 11.8-11.9.
I can't beleive the difference how my car pulls like a freight train now and I have no traction @ WOT 1st-5th!!!!!
Like I said.
ME BAD
Jun 24, 2005 | 10:43 PM
do u have any new dyno graphs of your kit?
looking for one that pulls all the way to 6500rpm
Jun 24, 2005 | 10:49 PM
Nope no new dynos and my car will never be on the dyno again as it's all in the road tune under real load.
Dynos are only good for a base run to get a base tune.
The more dyno runs you make on a motor the worst it is for the motor.
My car pulls strong all the way up to 6,500, if I feel up to it I'll post a graph that I saved off my data logger.
Jun 24, 2005 | 10:50 PM
Jay.....I drive my car all the time in Competition Mode, basically with the A/H on and T/C on, I wonder if this does the same as if they were both on??
Jun 24, 2005 | 10:53 PM
Quote:
I was told it does and when we turned everything off it was like night and day.
My car is totaly scary sick now with everything turned off.
Jun 24, 2005 | 10:56 PM
Very interesting.......Thanks!!
Jun 24, 2005 | 11:07 PM
Awesome!
Are you ready to be a camera car now?
Just don't pass me when I'm racing, k?
Jun 24, 2005 | 11:42 PM
St. Jude Donor '03-'06-'07-'08
Did the same thing. I would hit the pedal and around 5K the car would stumble and sputter. Told Doug about it and he asked if I had taken the traction control off. It seems when you get into the boost with A/H on it takes control because you are breaking the tires loose biggtime
Turned a/h off & no problem - well a different type of problem
Jun 25, 2005 | 12:00 AM
I thought that when traction control was turned off, the PCM was allot less intrusive. But then it appears everything should be turned off.
Thanks for the heads up.
Oh, is your C5 01 or newer, because I thought firmware was changed to address these issues?
Mike
Ahh yes, the joys of all the widget and dodads on the C5's
Kumar,
Sunoco 94 a wisker over 13psi and nothing else.
Jun 25, 2005 | 11:26 AM
Alan,
I thought you were away.
I guess it's a problem all us members of the tribe have!
Jun 25, 2005 | 11:43 AM
St. Jude Contributor
Did you guy's turn A/H off with LS1 edit???
Kevin
Jun 25, 2005 | 12:11 PM
Quote:
Kevin
Kevin,
Nope just by hitting the button on the console. I was at the shop when you called, I enjoyed your reply to my statement.
Jun 25, 2005 | 12:19 PM
Alan,
Online from London.
Jun 25, 2005 | 12:21 PM
Online from London.
Kewl have a great time it's going to be 98 here today!
Jun 25, 2005 | 12:25 PM
Kevin,
Kewl....... lol
Jun 26, 2005 | 12:05 PM
Quote:
Kumar,
Thanks for posting one up Phil.
Ahh yes all the joys of the dodads on the C5.
Jun 27, 2005 | 04:25 AM
Hello, I'm A Modaholic!!!
Jersey Jay, now I see why you were answering the phone on Friday. Chris was punishing you.
Jun 27, 2005 | 04:41 AM
care to explain that?
Jun 27, 2005 | 04:43 AM
Kumar,
thanks i have a 408 and i might want to do a turbo setup this winter
hoping there are a few stage x kits out there by then as well as Andy's kit
waiting for someone to run 15-18psi on a bigger cube motor
