Some advice
Old Jun 26, 2005 | 07:15 AM
denscor's Avatar
denscor
Default Some advice
I took my car to track and it was popping ,belt slipping ect! I checked my ltft and they were at 25 the stft were at 19.43 also timing was 23 degrees at idle ! So the problem I'm having is I'm changing to A&A bracket single intercooler right away ( I have the kit in the room) The car was tuned by Ed Wright throught a mail order tune ( because the closest place that does tuning is in NC and I'm in West Virginia which is about 6 hours away) Ed is telling me to get it on a dyno and give him all the ltft and timing curves and he can fix it by this through the mail :
, would this be a good idea or should I bit the bullet and that it to nc? I know if it keeps this up then it will blow up my car!!!!!!!!
Old Jun 26, 2005 | 08:19 AM
mdhmi's Avatar
mdhmi
I think it would be easier to install a WB02 and hook up a data-logger. I would do your long distance tuning with Andy @ A&A (if you have his kit) or some other shop with extensive experience with FI.
Mark
Old Jun 26, 2005 | 08:30 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I would be happy to help you as well.
I am in Knoxville, TN, so I don't know how far that would be for you to bring the car, but in this situation, paying someone a few hundred dollars and taking the car to have it tuned properly is much cheaper than the thousands you will spend to replace a motor.
I can give you a price via PM if you are interested.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jun 26, 2005 | 08:33 AM
jbkblown's Avatar
jbkblown
If I were you I would take it to ECS in New Jersey for a tune.
Old Jun 28, 2005 | 10:54 AM
mollydog's Avatar
mollydog
Default Problem
Why would you do a mail order tune with forced induction. It is imperative that you take your car to a company that does dyno tuning.
You mentioned NC was the closes place to you. You probably are talking about True Blue. It will be well worth your time to drive the 6hrs and get it tuned. It will be unbelievely at what they can do with your car. It also will give you peace of mind that your not hurting your car.
Good Luck.
Old Jun 28, 2005 | 01:52 PM
denscor's Avatar
denscor
I was thinking of More Performance; Where is this True Blue shop located at?
Old Jun 28, 2005 | 01:56 PM
SmoothFRC's Avatar
SmoothFRC
I have been in WV to run at the track there (the name escapes me at the moment) and it only took 3 1/2 hours or so to get there and ECS is only 1 1/2 from me - call it 5 1/2 hours, but I am sure it will be well worth the drive....
Old Jun 28, 2005 | 03:15 PM
denscor's Avatar
denscor
is it kanawha valley?
thats the track close to me !!
Old Jun 29, 2005 | 06:19 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Try giving Jeff Creech @ CAM a call. He has done a ton of FI. Great tuner and great guy. Hope this helps and good luck!
Dave
http://www.carolinaautomasters.com/
Old Jun 29, 2005 | 12:48 PM
SmoothFRC's Avatar
SmoothFRC
I was thinking summit point.
To Some advice
