Cam Question
Cam spec's 228/230 .590 113LSA or 114LSA
Any input would be appreciated, thanks in advance
Mike
Mike
I know you have an 04, the valve springs are the best that were offerred from the factory on a C5. I would go ahead and have those changed out when you decided to FI. They are fine for NA now.
Stay with the 114lsa...it will be better for the blower..however not a whole hell of a lot of difference at 113 vs 114 LSA on a 110 ICL. The lower the LSA the more the power band shifts towards the mid range.
That cam will give you about 30-40rwhp with your setup.
The LS6 heads from the factory flow better than a Stage I LS1 head. I have used at least 4 different cams in LS1s. The cam you are talking about using is not too much different then my cam..which I have used for NA, SC, and now 2 different TT systems. The cam you have selected is a great cam and I would not hesitate to use it for any application.
How does that sound ?? Its replacing a LPE GT2-3, which I feel isnt working well at all for me.
Thank's Kevin,
So I should go with this cam and not change
any of the spec's
? And later when cash is flowing buy the P1 or D1 from Andy?
I want to mod in stages so, I don't break the bank
Thanks again,
Mike
Go with the 114 LSA or even a 115, but definitely not the 113, this is if you are going to use the same cam with a procharger.
Like Kevin said, the stock Z06 springs will be good for now.
Remeber, I have a ported throttle body for you. install this all before you get a tune.
any of the spec's
Thanks again,
Mike
I would wait then and do a forged 402 short block with 10.5 to 1 when you are ready. Do everything else now, like headers, massive cooling, save $$$...Pop for the clutch setup when the engine is out.
Very very important to plan.
Brent
I was hoping on keeping this cam when I pro-charge, I think I am going to replace the springs and push-rods now, I will call Synergy and see what I'm getting.
Thanks for the Throttle body, I need to hook up with you, maybe a sunday cruise
See Ya,
MO
See Ya,
MO
Let's hook up with some of the gys and go to the drags! We went twice already.
Sounds good, let me know a date, so I can plan with the wife/kids
