CATCH CANS question & help
Old Jul 18, 2005 | 08:46 PM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
Default CATCH CANS question & help
Anyone install a Greddy Catch can? whats the best way to install the tubbing, also can i tee off any vacum line off the intake to the can or does it need to be by it self? A diagram would be best since i never installed one .... the tubing off the can is kinda large there are 2 lines both the same size ..looks like garden hose.........
Old Jul 18, 2005 | 09:21 PM
IM QUIKR's Avatar
IM QUIKR
Because I have a blower on mine I re-routed the hard line from above the valve covers by warming the plastic pipe and straightening it to run along the firewall and over across the battery box. The catch can is attached to the battery box and the hose runs around the oil filler to the check valve and to the vacuum port on the intake. Without a blower occupying so much space you can attach the catch can to the heads and tap into the PCV system right up close to the intake. I hope this helps. In the picture you will see the CH filter which has been replaced with the AMW catch can. It work very well now.
