studs or bolts
Old Jul 21, 2005 | 06:27 AM
denscor's Avatar
denscor
Default studs or bolts
Since I have to replace head gaskets which is better for a FI car studs or bolts? Also do you torque ARP studs or bolts same way you do factory bolts?
Old Jul 21, 2005 | 06:39 AM
SS930's Avatar
SS930
Studs... and yes, same pattern.
Old Jul 21, 2005 | 09:00 AM
kromberg's Avatar
kromberg
Studs provide a better clamping force than bolts. Definately worth the investment with FI applications
Keith
Old Jul 21, 2005 | 09:14 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Studs all the way. Makes changing the heads a little more difficult since you have to raise them a little more to clear the studs, but the mild additional effort is worth it.
Old Jul 21, 2005 | 01:05 PM
Scubanme's Avatar
Scubanme
Studs, they are more resistant to pulling because.......... they spread the load to the end with the nut and the other end of the stud that is threaded into the block, so the load is 50-50 on each end. Head bolts place all the load soley on the threads that are in the block.
You use the same torque pattern as factory, but not the same method.
You don't use the torque angle gauge.....because the factory bolts are stretch to yield . Use the standard torque wrench for the studs.
Old Jul 21, 2005 | 03:58 PM
denscor's Avatar
denscor
great I going to get studs
Old Jul 22, 2005 | 01:27 AM
s2000kid's Avatar
s2000kid
I have a set of ARP LS1 head studs that i can't use with my 04 LQ9 block. They are brand new. These are the 6-point nuts ARP part number 234-4110. Will sell them for $200+ shipping if you are interested.
Old Jul 22, 2005 | 06:00 AM
denscor's Avatar
denscor
are they new or have they been installed?
Old Jul 22, 2005 | 12:42 PM
s2000kid's Avatar
s2000kid
I have ran 2-3 of them into the block by hand and quickly noticed the 7" studs were way too long. I then did some research and found out the 04 castings were changed to accept only 5" studs. This means I need a totally different kit. The studs have never been torqued and all nuts/washers/studs are in original packaging. It includes: four- 5" studs, sixteen- 7" studs, and ten- ~3" small studs with all nuts and washers and directions.
To studs or bolts
