Installing my HP performance kit
I got my tracking# for the missing carbonparts from HP friday, so i went down to the garage and started the install of the kit today. Almost finished with installing drivers side turbo.
I had to use the hammer on the header to make it clear the steering axle.
Otherwise it is fitting nice (left side only so far).Haven't got any instructions yet so i am not sure where to put my oilreturn yet. Does anyone have a picture of the inside of an oilpan or better yet a description of where to put it.
I can see on HP's website the approx location on the left oilreturn, but not the right side...
I am taking some pics as i go along. Here they are:
http://spaces.msn.com/members/motorm...&_c=photoalbum
Roger
Need to have a website to upload your pics to. Go to your website and right click on the pic file, highlight and copy the pic "address", and then put that address within image tags like this :
(img)address here no spaces(/img)
I used () when you are supposed to use []... so that my example will show up so you can see it.
Bill
Bill
If you like... I can host for you until you get your website up and running. You can send the pics to billreid1@***.net
FYI, there are also some websites that will allow you to post your pics to their website and you grab the address from there. I think cardomain.com is one of those places...
Whatever works the easiest for you
Bill
Choose the category "bilder" and "HP Turbo"
Link:
Does anyone have a picture of the inside of the oilpan?
I would like to see where to drill holes for the return safely.
Roger
Now, this is the driver side drain for a TTi kit. The fitting is 3/8" so this is an older shot... since then TTi has moved up to 1/2". I don't have a shot of the passanger side but you get the idea. For the passanger side the drain will be located a more towards the front of the motor because of the starter. There is a spot between the starter and the A/C compressor.
I'm not sure this setup will work for you but it gives you an idea.
Bill
Bill
That's exactly the spot i thought i should use.
I have just fitted the pass.side header and removed batterybracket from the frame. I will bring the tools to drill and thread the returnholes from work tomorrow. When that is finished i can permanently install the turbo's.
Another thing that i don't know what to do with yet is what to do with the pcv/egr and airpump. Still haven't got instructions from HP
Roger
... you don't need no stinkin' instructions
You should be able to relocate the pump, right in front of the crash pad (with minor trimming of the pad itself), here:
I was thinking of removing the tubes going to headers, but keep the pump. That way i was hoping to avoid codes....
Welding and recoating is not an option since i live in Norway and there is a long way to Tempe Arizona (JetHot)!
We have vehicle inspection every second year here in Norway, but it is done at authorized workshops wich i happen to be a manager of
I am still going to run cats though!
I am not able to see how the tubing goes behind the intakemanifold so i don't know how/if the egr is connected to the pcv.
I would like to see a schematic drawing/picture and description of the whole system if someone could provide...?
Roger
The air pump draws air from the factory air filter box and then pumps it through (1 for each exhaust manifold) 2 check valves and then injected into the exhaust manifolds. Thats all there is too it really (hardware wise)... just some piping that wraps around the back of the engine. The passanger side air pipe is bolted to the back of the drivers side head. Taking the intake manifold off will allow fairly easy access to loosen the bolt and then you can remove the entire air pipe assembly. By the way, the air pipe system is not hooked up to pcv... so removal of the air piping will not affect it. Also, there is no exhaust gas recirculation (EGR) on the C5... at least US Spec models... is there EGR on Euro export models?
Bill
But i suppose i can't leave the pcv in stock condition?! Then i will pressurize the crankcase in boost condition, or at least it will not ventilate at all when checkvalve is closed during boost.
Or is there something special arrangement on C5's or us spec car in general that i don't know about?
Sorry about all the stupid questions, but there is impossible to see what goes on behind the intake, and there are clearly some other antipollution rules in Euro cars wich i am most familiar with. :o
Roger
In my opinion it is not a direct bolt-on kit.
You need some skills to install this yourself.But i do have some progress every time i spend time in the garage
I have teared off the batterybracket from the frame.
More pics to come later
Roger
Roger
But for future customers i think the wait will be considerably shorter, because the kit is still in development. They have moved the WG since i ordered, they have included a optima redtop battery and they have also decided to make a shroud over the radiators/IC in the kit.
(i am not trying to defend them for the long wait, but it seems like they want the kit to be complete and great)
Roger
