Which plugs
Old Jul 26, 2005 | 09:17 PM
mitymikec's Avatar
mitymikec
Default Which plugs
I am looking at putting the jug on the car this week. With a 100 hp dry kit should i be using ngk tr5 or tr6 plugs? what is the most one should spray with a dry kit? one more thing, i was thinking of using my old nos dry kit from my mustang and only using one solenoid. If i decide to run only one line into the air box instead of two lines as the nos 5117 kit shows, should i be using a bigger jet to srpay 100hp given that it will only be spraying on one side of the air box.
Old Jul 26, 2005 | 10:05 PM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
I would use TR6's. I sprayed a 125 dry shot on my LS1 for a couple of years with no problems. You will have to run a bigger jet if using 1 to adjust for the difference. Best call NOS for the conversion info. I also would definately fun a RPM window switch, fuel pressure safety switch, WOT switch and redundant N2o solenoids for added safety
Enjoy!
Old Jul 26, 2005 | 10:20 PM
mitymikec's Avatar
mitymikec
what size of jet did you use for the 125 hp. did you use race gas? what gains did you make with the 125hp?
Old Jul 26, 2005 | 10:38 PM
longdrive70
Twin Turbo Coupe
I will have to look at my notes for the jet size, used the largest ones with the kit and then had them machined out a few 100ths out....all of this was done on 93 octane gas... I did have the MAF recalibrated to provide additional fuel when spraying....never made it to the dyno
Old Jul 27, 2005 | 12:30 AM
kendo347's Avatar
kendo347
I use the ngk tr6 as well with a 125 shot.
Old Jul 27, 2005 | 06:52 AM
XTrooper's Avatar
XTrooper
The NGK TR6IX iridiums are great!
Old Jul 28, 2005 | 07:15 PM
mitymikec's Avatar
mitymikec
What size of jet gives you 125hp
Old Jul 28, 2005 | 08:22 PM
Brian Laser S4
Guest
Posts: n/a
TR6's @ .035
Old Jul 29, 2005 | 12:28 AM
Shinobi'sZ's Avatar
Shinobi'sZ
I recommend TR6s gapped between .035 and .039.
I am currently running TR7IXs gapped at .035
To Which plugs
