A&A install tips
Old Aug 5, 2005 | 05:17 PM
exploder's Avatar
exploder
Default A&A install tips
Well guys, it looks like I will be receiving my A&A kit middle of next week and will be installing it myself. I was wondering if anyone out there that has already done the kit can point me in the right direction to some tech articles or links that can explain a few things to me such as
1. description of fuel pressure and bost gauge install (where are you tapping in for vacum? maybe a picture....and how do you pull the wires through the firewall.)
2. pinning the crank ( I bought the kit from A&A already) any tips or tricks to doing it.
3. routhing the pulleys around the alternator (supposedly there are changes between the alternators or bracketry that makes you route the belts differently....I have an 03 z06 if that makes a difference)
4. Racetronix new wiring harness for 03 and up c5's...anyone have any idea how this is going to interface with the KB BAP or any tips on putting it in and a good place to put it.
5. Any general tricks or anything that you might remember from your own personal installs that might help me out would be greatly appreciated.
Old Aug 5, 2005 | 06:11 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The only advice I can give you is keep Andy's number handy. He forwards his phone to his cell so you can pretty much call him 24/7. Believe it or not he eccourages it. I've talked to him at darn near 10 o'clock at night.
In regards to the Racatronics pump, I mounted the relay onto one of the fuel filter bolts right above the drivers side tank. Then I ran the wiring inside the tunnel (above the tunnel plate) all the way to the front. I then fished it up on the drivers side and mounted it to the alternator. I bundled up and zip tied the excess wires next to the master cyl.
Its pretty straight forward. If you go onto A&A's site the have install instructions..
Jeff
Old Aug 5, 2005 | 07:40 PM
Brian Laser S4
Guest
Posts: n/a
You can use this as a supplement to Andy's pics. You can also hit me on AIM, I am more than happy to help.
My Build
Brian
Old Aug 5, 2005 | 07:45 PM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
NICE JOB BRIAN,CANT WAIT TO RACE YA
Old Aug 5, 2005 | 08:23 PM
1 Nasty Z's Avatar
1 Nasty Z
My Build
Brian
Hey Brian I have a A&A kit on order. I wonder if you could post a pic of your finished product showing the alignment of the front (center) air dam which has to be relocated per the instructions. I wonder how far off or rather how far forward it aligns with side air dams. So I guess I'm asking for a side picture. Would be very appreciated.
Thanks in advance
Troy
Old Aug 5, 2005 | 08:40 PM
denscor's Avatar
denscor
great pictures Brain way to go !
Old Aug 5, 2005 | 08:42 PM
Brian Laser S4
Guest
Posts: n/a
Thanks in advance
Troy
No problem Troy, I have the pics in my office, and will drop some tomorow. In the mean time, go out and get yourself some expanded metal, a nice cross hatch patern for underbody FOD (foreign object debris) protection and some black paint. Paint it so it is ready to be cut to size. Be prepared to trim some excess nose underneath. Get some radio backstraps to,some nuts and bolts, smaller than 1/4" in a wide variety in lengths. do the home depot run, over buy and return what you don't use. it will all make sense when you see the pics.
fyi, my dams are even all the way across. If you skirts are beat, now would be a good time to replace.
till tomorow
Brian
Old Aug 5, 2005 | 09:01 PM
exploder's Avatar
exploder
Thanks alot for the pics...this is exactly the kind of stuff I was looking for.
Old Aug 5, 2005 | 09:08 PM
Brian Laser S4
Guest
Posts: n/a
Practicing for our BMW supercharger kits that are coming out soon. In terms of the pics and instruction side, step by step deal. My goal is to write it in a way where there is minimal questions involved in terms of our entry level s/c kit.
Old Aug 5, 2005 | 09:10 PM
IM QUIKR's Avatar
IM QUIKR
The B*tch of it all was the crank pinning. After that the rest was a snap. All I can say is follow Andy's instructions carefully. If you don't have them ask him for them. Good luck.
Torque specs
Crank pinning
Old Aug 5, 2005 | 09:17 PM
Brian Laser S4
Guest
Posts: n/a
Mine wasn't to bad but I have a lift.
Old Aug 6, 2005 | 02:43 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
The Racetronix relay and BAP mount in the DS rear fenderwell where the filler neck is:
The grounds from the booster hook to the chassis and relay ground point. There is a booster connector set included with your harness. The male connector is installed on the booster B+ input and plugged into the female booster connector on the Racetronix harness. The female connector is installed on the booster's + output wire and plugged into the male connector on the Racetronix harness.
Old Aug 6, 2005 | 11:29 AM
exploder's Avatar
exploder
I think this could be stickied to help others later....I will take pics of my install and note things as well
Old Aug 6, 2005 | 11:49 AM
Brian Laser S4
Guest
Posts: n/a
Undercaridge protection
Use the old holes and clips to secure the expanded metal to the nose on the front and then sandwich it between the cross bar and the skirt.
You will have to trim some of the tabs on the front side of the nose sdo the screen sits flush and nice. Take your time on this finish part of the build and do it last after you have made all your clearence adjustments in terms of the gap between the Rad, FMIC and condensor core.
Injectors Ford SVO #42
Brian
Old Aug 7, 2005 | 01:01 PM
1 Nasty Z's Avatar
1 Nasty Z
Thanks Brian!
Nice looking
I thought the center section would sit more forward than the sides. I will have to figure out what to do about that when the time comes.
Troy
Old Aug 7, 2005 | 03:07 PM
FreddyG's Avatar
FreddyG
1 Nasty Z: You might want to give some thought to a Big Mouth air dam for the front. I put one on my car and took the middle spoiler off, but you can mod the spoiler to fit back on if you'd like. I have a stock thermostat/cooling system and in 95° weather my coolant temps were around 200-205°, but then got on the highway and they dropped to under 200°. I'm going to put in a 170° thermostat and have the fans reset, and that should help some.
Big Mouth air dam
If I'm not mistaken, he's a supporting vendor here.
By the way you've got a WICKED looking car!
Old Aug 7, 2005 | 06:03 PM
1 Nasty Z's Avatar
1 Nasty Z
Thanks LuvmyC5
I may have to look into this. I also might try to make my own setup like that.
Thanks for the compliments.
Troy
Old Aug 7, 2005 | 07:35 PM
FreddyG's Avatar
FreddyG
You're Welcome.
To A&A install tips
