Magna-Volt ... anyone tested it
Magnuson Products, manufacturer of superchargers and supercharger systems for foreign and domestic vehicles is pleased to announce the availability of the innovative “Magna-Volt”.
A digital, dual-input fuel voltage controller is available for sale individually, and as an upgrade to the Magna Charger line of supercharger systems. The digital function has the advantage of linear power flow and reliability. The Magna-Volt will allow for high-performance fuel delivery based on 2 variables; RPM and boost. When the Magna-Volt sees a predetermined RPM and boost level, it increases voltage to the stock fuel pump to 17 volts at 20 amps. Using 2 variables maximizes fuel economy and pump life, while still allowing for the high performance modifications enthusiasts love. The Magna-Volt will come pre-set and ready to install with wiring harness and full color installation instructions.
· Full Digital Operation – Integrated digital operation features modern technology.
· Dual Input – While reserving room for additional input, the unit is currently designed to monitor both boost and RPM, raising fuel pressure only when needed. This method ensures better performance, mileage and long pump life.
· Stock pump – The Magna-Volt was designed to work with the stock fuel pump, alleviating extra expense and labor.
· Plug-and-play – Nothing to set or adjust, the Magna-Volt arrives pre-set. Installation harness and instructions are included.
Looks pretty cool, I wonder what's the difference between this and the KB Boost-A-Pump
