Best sleeper setup
Old Aug 8, 2005 | 11:49 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Mine!
Old Aug 8, 2005 | 11:57 PM
Scubanme's Avatar
Scubanme
A true sleeper is a 150 shot.
Old Aug 9, 2005 | 12:29 AM
Z06VET's Avatar
Z06VET
Thats what I wanted also , Power and Stealth . I didn't want the whine of a blower either . From the downloaded sound clips of various forum members , I choose TT's over blowers just for that reason. I am amazed at how quiet my Twins really are , about half as loud as stock ! Even with the cats gone.
Twins are the way to go if you want the " always there " power without drawing attention to yourself with a jet engine noise coming out from under the hood. It just seemed wrong to have that sound coming out from a car that looks like as sleek as the Corvette .
Currently I am running 10 psi and about 600 Rwhp on the stock internals .
So far so good , but I just got the kit installed and am loving every minute of it .
Good luck on your decision .
Dan
Old Aug 9, 2005 | 12:23 PM
z06pdq's Avatar
z06pdq
From: Only in America can you get paid that much money for crying --the state of Texico
what HE said!!!
Old Aug 9, 2005 | 01:31 PM
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
Originally Posted by jersey jay
Mine!
NOOOOOO Mine
Old Aug 9, 2005 | 01:52 PM
1%r's Avatar
1%r
Originally Posted by asmokegars
NOOOOOO Mine
OK Alan...........I give but which one?
Old Aug 9, 2005 | 02:11 PM
GR8-LIFE's Avatar
GR8-LIFE
I Have an LPE TT and up until I got the LPE TWIN TURBO Fuel Rail coverd they did not know she was a TT until I told them. They were burrying their heads in the engine compartment asking "Where are the turbos?"
Old Aug 9, 2005 | 02:15 PM
GR8-LIFE's Avatar
GR8-LIFE
Originally Posted by Vette Doc
The TTiX is a decent kit which can be modified to the LPE standards, but will in the end rival it in cost to do so.
Mike Norris
with Mike on this. At best its splitting hairs and then you gotta comare that to the number of C5 TT's LPE has done. They are well into the few hundreds in terms of those numbers
Old Aug 9, 2005 | 02:24 PM
DDSLT5's Avatar
DDSLT5
Over 350 LPE TTs done when I asked last in May.
Old Aug 9, 2005 | 02:26 PM
DDSLT5's Avatar
DDSLT5
Dan
BOOOOOOOOM!!!!
Seriously - start deciding on what company you want to use for the forged engine you're buying next spring!
I have a buddy in Edmonton -two actually. One is having his ZR-1 twin-turboed! He will come and look you up when its done!
Old Aug 9, 2005 | 02:29 PM
GR8-LIFE's Avatar
GR8-LIFE
Dan
Originally Posted by DDSLT5
BOOOOOOOOM!!!!
Thats what I was thinking.
Old Aug 9, 2005 | 02:30 PM
GR8-LIFE's Avatar
GR8-LIFE
with Mike on this. At best its splitting hairs and then you gotta compare that to the number of C5 TT's LPE has done. They are well into the few hundreds in terms of those numbers
Thats pretty damn impressive. Soon there will be more LPE TT'S Than VIPERS
Old Aug 9, 2005 | 03:15 PM
  #33
mdhmi's Avatar
mdhmi
There are tons of cars running around with 550-600 rwhp that last for years at those power levels. It's all in the fuel and the tune.
Mark
Old Aug 9, 2005 | 03:22 PM
  #34
GR8-LIFE's Avatar
GR8-LIFE
Mark
not TT's from one tuner and I think he's looking for a TT and for it to be stealth.
Old Aug 9, 2005 | 03:24 PM
  #35
rsxmanjoe's Avatar
rsxmanjoe
Whats the TT kit cost again?? For a stock bottom end?
Old Aug 9, 2005 | 03:29 PM
  #36
GR8-LIFE's Avatar
GR8-LIFE
TTi is around $14K (I think ...)
LPE's is 18K for an MN6 ($21K for an A4 I think) but also includes a conservative HC and the exhaust of your choice. The LPE Warranty is 2 years. Not sure what the TTi is. About 502-515 rwhp with the LPE Stage I TT. Will give you about 6 lbs of boost.
Where do you live?
Old Aug 9, 2005 | 03:31 PM
  #37
rsxmanjoe's Avatar
rsxmanjoe
LPE's is 18K for an MN6 ($21K for an A4 I think) but also includes a conservative HC and the exhaust of your choice. The LPE Warranty is 2 years. Not sure what the TTi is. About 52-505 rwhp with the LPE Stage I TT. Will give you about 6 lbs of boost
Isnt anything over 10k sort of ridiculous for a bolt on twin turbo kit?? The majority of a turbo kit is pretty cheap, the only things that are more of a "Custom" piece are the manifolds....Everything else can be bought for a few grand...
To Best sleeper setup
Old Aug 9, 2005 | 03:52 PM
  #38
DDSLT5's Avatar
DDSLT5
Mark
Yes - but you're mostly talking about procharged cars that have a very peaky power curve, thus saying that the torque curve is pretty friendly. Only time these cars make 600 rwhp is right before redline, thus a very limited rpm range - and how long are they living there? Now, with a TT, you'll make peak before redline, and likely hold it to redline, extending the range over which this critical power level is produced in the engine.
What's the point? I think 600 rwhp is really pushing it on the stock pistons - one little thing gets out of whack, and you've melted a piston. On the other hand - if it wasn't such a pain in the ***, I would have run 585 rwhp on my stock bottom end for a while just to see how long it would last, but of course, then I wouldn't be able to turn up the boost either.
Old Aug 9, 2005 | 03:57 PM
  #39
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
The TTi kit is about $10K with ball bearing turbos.
As you can imagine, the market for C5 twin turbo systems is somewhat limited. It's hard to make up the fixed R&D costs in volume, so each kit will cost a bit more than you'd ordinarily expect given its components.
Old Aug 9, 2005 | 04:11 PM
  #40
GR8-LIFE's Avatar
GR8-LIFE
Ridiculous? Show me where all the other C5 TT's are if you think it is so simple and cheap to do.
I cant speak for TTI but LPE is not a bolt on. It requires lots of labor, the parts are top of the line and if you saw setup you would see why it requires so many hours work. The turbos are put down low I believe beause the C5 is a true bottom feeder. Remember, there is also a HC as part of the package.
Is LPE a bit overprieced? Maybe - maybe not but if they are its not by much and like any other business, until there is some TT competition, the price will remain up there
