Transmissions...
Old Aug 10, 2005 | 12:33 AM
Z06VET's Avatar
Z06VET
Default Transmissions...
Having an issue with 4th gear grinding when trying to engage it , sometimes it even sticks in 4th and can't be shifted out of until I reduce speed. I have been told it might be the synchros have gone out of alignment . Whatever it is , the transmission apparently needs to be redropped down ( since the newly installed clutch ) . I am wondering since it's going to be down again anyways if I should look into some trans upgrades . Hardened output shaft , 3/4 hardened syncro key , steel shift fork assembly and an overhaul kit have been suggested .
Trying to get some feedback on how to proceed ... looking at a $ 4500 - 5000 bill . (includes labour for R&R + rebuild )
Dan
Old Aug 10, 2005 | 12:47 AM
Sack Rat TT's Avatar
Sack Rat TT
I have heard of the same symptoms you are having presently caused by the clutch, probably not totally releasing. Just somewhere else to check on when you teardown. BTW, I just rebuilt my tranny, MN-6 with factory 1 thru 4 ratios, however, 5th and 6th lowered to :70 overdriven 5th and :80 overdriven 6th. As an example, with the factory 6th ratio I was going 93MPH at 2,000 rpm wheras now in 6th at 2,000rpm I am going 67MPH. In 6th, at redline, no tire slippage, I theoretically will be doing 196mph. This puts all the six ratios in a realistic range for a street driven car, a car not taken on long highway trips where mileage could be important.
Just another option for you to look at. Good Luck
Old Aug 10, 2005 | 08:48 AM
kirbyloid's Avatar
kirbyloid
Default trans
Dan
Get in touch with Rodney crashed94 in my signature he will hook you up
Old Aug 10, 2005 | 09:17 AM
JeremyMSG's Avatar
JeremyMSG
Old Aug 10, 2005 | 02:51 PM
Z06VET's Avatar
Z06VET
Trying to get this done locally guys . Coming over the border for this just isn't in the cards .
But will give him a call at least.
Dan
Old Aug 10, 2005 | 02:57 PM
kirbyloid's Avatar
kirbyloid
Default trannie
Dan
Do call he ships daily
Old Aug 10, 2005 | 11:21 PM
Z06VET's Avatar
Z06VET
Old Aug 10, 2005 | 11:27 PM
xlr8shn's Avatar
xlr8shn
I got a rebuilt T56 from rodney for $1500. Put it in myself
Old Aug 10, 2005 | 11:28 PM
XCELER8's Avatar
XCELER8
Sent you a PM, guess you didnt get it.
Jon
Old Aug 10, 2005 | 11:54 PM
roythomas's Avatar
roythomas
your defently in for rebuild been there twice in two year with hard driving & big hp its almost a yearly thing
Old Aug 11, 2005 | 01:34 AM
Z06VET's Avatar
Z06VET
Jon
Thanks Jon , sent back reply .
Dan
Old Aug 11, 2005 | 09:14 PM
Z06VET's Avatar
Z06VET
Talk about timing , couldn't get into any gear besides 3rd as I was 1 block away from the shop on my way to check on my lost boost pressure issue. If it was going to pack it in , at least it saved me from some larger hassles.
Mark from Campbell Automotive talked to Rodney and he will build a tranny for me and send it up . Saving me a few bucks in the process compared to our local guy. Who I think was trying to stick something in my a$$ .
After just getting the car back , it's 2-3 weeks more in the shop and out comes my wallet again as well.
Damn , need some more play and less pay.
Dan
ps Thanks for the tip on Rodney and other options .
Old Aug 11, 2005 | 10:49 PM
BadMonkey's Avatar
BadMonkey
Another one hear for Rodney. I cannot say enough on how much he helped me out on mine. I watched him rebuild mine in less then 2 hrs. And he could have been done quicker if I not keep talking to him I watched him do his work, and he will see more from me in the future I promise you that.
Damon
Old Aug 11, 2005 | 11:51 PM
mdhmi's Avatar
mdhmi
Many of us, unfortunately, have experienced that.
Good Luck,
Mark
To Transmissions...
