Nitrous question
Aug 21, 2005 | 07:38 PM
Nitrous question
If I run 12.3's with bolt on's and wanted to run a 150 shot wet kit what kind of times could I run and how safe would it be to a stock motor?
and what would the best kit be?
Thanks in advance
Vic
Aug 21, 2005 | 08:03 PM
My guess:
150 shot with tuning, 11.5-ish maybe better, with sticky tires.
safe: 150 shot is the max for a stock bottom, that is if you want it to last.
I use NX Express.
Good Luck....Have fun....!Go fast!
Bruce1
Aug 21, 2005 | 08:48 PM
NX wet kit vic. i know some who run a 200 shot easily on stock bottom end w/o a problem w/ quite a few passes. I bet you go low 11s if you spray it off the ilne and get traction>
Dave
Aug 22, 2005 | 12:59 AM
I think you might wanna get a better fuel pump. If you are running 12.3 now you gotta have near 350RWHP???? then throw on another 150hp plus near 200tq. Stay on the safe side get a better fuel pump. As far as keeping the motor safe just make sure you use the safty parts (window switch, fpss,) That extra money will make a diff from a blown motor and a working motor. And dont spray under 3k..
Aug 22, 2005 | 01:02 AM
its a wet kit he should be fine w/ that pump.
Dave
Aug 22, 2005 | 01:18 AM
Quote:
Dave
whoops my bad....
Aug 22, 2005 | 01:22 AM
Quote:
Originally Posted by bruce1
My guess:
I use NX Express.
Bruce1
Aug 22, 2005 | 07:10 PM
I have a 100 shot with intake and exhaust, want to go 150, its a wet kit. I know several ls1's around here doing it with no issues, what do you guys think ?
Aug 22, 2005 | 08:29 PM
my times w/ bolt ons were 12.6 -12.8. w/100 shot (nx kit) 11.3-11.5 @ 122mph. i don't have a rollbar and i've been warned by the track officials,so i can't try the 150 shot.
Aug 22, 2005 | 09:28 PM
thanks
My best time so far was 12.3 at 108
Im running at about 345 rear wheels hp with bolt on's
I think this is gonna be my next mod
then some drag radilas for sure
Vic
Aug 22, 2005 | 09:31 PM
should be around low 11 possibly a high 10 with some decent traction and if you get a clean pss in.
Aug 25, 2005 | 04:38 PM
TNT instruction manual says to use an additional fuel pump at 150 or more
Aug 25, 2005 | 05:26 PM
Quote:
ah yes indeed,,,,, I do! or else it could go boom'
Aug 25, 2005 | 10:53 PM
My guess:
I use NX Express.
Bruce1
How long does a bottle last (how many runs)?
Aug 25, 2005 | 11:38 PM
Quote:
A small 15lb bottle will yield:
@ 250 shot you can get 3-4 runs
@ 200 shot you can get 4-6 runs.
@ 100 shot 8-12 runs
Aug 26, 2005 | 02:36 PM
Thanks for the info Bruce. I always wondered how much you could get out of those bottles.
Aug 29, 2005 | 09:23 PM
where is the best place to buy the NX kit? or whats the part number of the kit that is everyone is talking about?
