What N2O system is C5 specific?
Old Aug 24, 2005 | 09:02 PM
DougG's Avatar
DougG
Default What N2O system is C5 specific?
I noticed that many members have used the NOS 5177 system although it is not specified as a C5 system by NOS, but only Camaro/ Firebird. Why? Are there any Quality systems designed Specifically for the C5 LS1? I am looking for a full featured, totally safe 75 shot dry system for DIY installation. Wimpy but bulletproof
Old Aug 24, 2005 | 09:58 PM
jophis37's Avatar
jophis37
suscribing,
think of all the money you would have to put into your car to get 75 rwhp, if it wasn't on the bottle
Old Aug 25, 2005 | 04:18 PM
H20Vette's Avatar
H20Vette
ttt
Old Aug 25, 2005 | 06:34 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
The ONLY reason the 5177 kit is not C5 specific is because the WOT throttle switch cannot be mounted on the Corvette where it is designed to go on the F-bodies because of the vette's fly-by-wire throttle system. That is the ONLY difference......and it is specified for F-bodies because they can get a CARB approval (ie - smog legal) when used as designed. You can get around this by mounting the WOT switch under the gas pedal as most of us using that kit in C5's do.
Old Aug 26, 2005 | 01:49 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
It was a very easy install.
Old Aug 26, 2005 | 07:56 AM
speedz06's Avatar
speedz06
I'm using the tnt power ring kit--made for the ls series engines--theres also the NX MAF setup for LS engines.good luck with your install
To What N2O system is C5 specific?
