Nitrous Hook up
Old Aug 28, 2005 | 11:06 PM
1BAD97VETTE's Avatar
1BAD97VETTE
Default Nitrous Hook up
I bought a basic NOS kit of off ebay for a fuel injected car... i know that my car does not have the throttle cable which i guess enages a normal car for nitrous to activate at WOT... so i was just wondering if i need anything extra to hook this kit up, if so what all do i need, and how hard is it to hook up
THANX
Old Aug 28, 2005 | 11:09 PM
1BAD97VETTE
PART # is 05123NOS
Old Aug 28, 2005 | 11:12 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
If it comes with a WOT switch just mount it under your gas pedal.....that's what all of us with the 5177 kits do.
Old Aug 28, 2005 | 11:19 PM
1BAD97VETTE
im not real familar with these NOS kits.. but what is the difference in the one that i purchased and the 5177 kit.. also would it be fine to keep the OE plugs in there... and how do these motors hold up to the NOS i plan to run no more than a 75-125 shot verry ocasionally....
Old Aug 28, 2005 | 11:22 PM
kman0066's Avatar
kman0066
If the car is a 6 spd, then you absolutely need a Window Switch
Here is an example of one: http://www.dynotunenitrous.com/store...?idproduct=138
Without one, if you miss a shift or hit the rev limiter, it won't be pretty.
If the car is a automatic, it is still a good idea, but not absolutely necessary.
The switch will turn the Nitrous on and off at certain RPM's you program into it. 3000 is a good starting point to prevent puddling of fuel.
Old Aug 28, 2005 | 11:27 PM
1BAD97VETTE
Its an A4... i might still go with one... is these kits hard to install??
Old Aug 29, 2005 | 12:51 AM
X-ZZ4's Avatar
X-ZZ4
I don't know much about a 5123 kit......but most kits share major components. I saw that kit is for a 4 or 6 cylinder, so I'm guessing it has smaller jets and the nozzles may be different than the 5177. The relay may be different too although I really don't know....also.....I'm guessing it's a single fogger setup instead of the dual fogger like a 5177. Worst case scenario is you can buy the individual pieces that are different and end up with the same parts as a 5177 afterwards.
The kit is pretty easy to install......mostly it's wiring. Any average DIY type guy can get it done in 8 hours or less.....and that's taking your time. It took me a little longer (2 weekends) but I'm slow and I always have constant interruptions from my two kids......
Old Aug 29, 2005 | 12:58 AM
1BAD97VETTE
ok what do u mean by the foggers??? im not to familar with that... i have a buddy who can loan me some bigger jest...
Old Aug 29, 2005 | 01:00 AM
1BAD97VETTE
http://www.mpsracing.com/images/prod.../13700Rnos.jpg
hmmm im lost now loll... i knoww what the fogger is but why would you need more than 1??
Old Aug 29, 2005 | 01:18 AM
kman0066's Avatar
kman0066
One fogger will be fine for a small hit, i.e. < 150hp.
Old Aug 29, 2005 | 01:19 AM
1BAD97VETTE
ok so does that mean if you have 2 foggers you have to drill into your intake in 2 different spots???
Old Aug 29, 2005 | 02:16 AM
X-ZZ4's Avatar
X-ZZ4
Here's mine on my Vararam.....
To Nitrous Hook up
