There is a shelf in the bottom of the center compartment, that you should be able to press fit. Make a template from a piece of cardboard.
if you dont need to pass NHRA tech, you can mount the wood with industrial velcro, or you can run bolts through the tub and secure from under the car.
ha i want the bottle mounted like inbetween the two seats in the back you know like in the center... but i would be able to get nuts started on bolts from under the car ... i know some one has done this before grr errr.... aslo how is people hiding there selnoids on here.. im having a hard time doing that to
thans
Here may be some ideas/insight, off my web site.
From '97 Coupe:
From my '02 Z06:
Wot throttle sw:
Robert
i got the switch mounted... i also got the bottle mounted but i had to do it on the peice of wood that corvers the compartment in the back... i wish it could be farther up like the second pic you showed... how did you get that front brace stable??
Front brace on both installs is a piece of plywood glued with Gorilla snot then screw to. The rear mount on both is through bolted with access from underneath for nuts/washers.
Robert
