My current PCV
Old Sep 7, 2005 | 11:15 AM
RED99's Avatar
RED99
Originally Posted by QuickSilver2002
Yes, I have actually tried that and I still have part of it on my car. It has to be hooked up after the mufflers on a car with a full exhaust. There cannot be any backpressure for the venturi to work. I routed alum lines up into the engine bay (boy was that a PITA). You can actually see the line in the pic in the first post.
It only works at WOT and high RPM and the air that it moves is pretty minimal. It also pushes a little exhaust back upstream in non WOT conditions (it has check valves but they let a little air move between pulses at low RPM). This is not an issue if you are just venting, but it is the reason I don't have it hooked up right now. I might try it again at some point, but my current thought is that it is not worth it.
I actually have the ability to data log crankcase pressure with my setup, so I plan to do several different experiments once I get some other tuning issues worked out (I’m in the process of switching to SD and removing the MAF right now).
MAybe this is why I only see this set-up on drag races, because they are either idling, or WOT.
Old Sep 16, 2005 | 12:06 AM
QuickSilver2002's Avatar
QuickSilver2002
I'll post a data log within the next week or so. It will show Kpa in the crankcase.
Ok, the new SD tune is finally coming around. It is a real PITA without a dyno .
Anyway, I logged the crankcase pressure today. Here is a quick graph of what it is basically doing.
Note: Atmospheric on the CC pressure sensor was 102 Kpa. The gridline at 101.5 kap is just below atmospheric for that sensor.
Click on thumbnail to see full size.
It looks like it is hitting about .25psi of pressure in the CC. I did make one change to the system while hooking it up. The solenoid that dumps to atmosphere now opens at about .5 psi.
I’ll be making some full pulls to redline soon. I seem to also be having a little belt slipage. I'll be throwing on a new belt tomorrow (think this one is more than a year old).
Old Sep 16, 2005 | 08:11 AM
IM QUIKR's Avatar
IM QUIKR
QS,
What I see is the baseline is 102kpa and on decel and cruise you have about 90kpa (vacuum) and at WOT you have about 105kpa(positive pressure). If that's correct the system is a failure. You are generating vacuum at rest and pressure at WOT. This is contrary to the desired objective to gain vacuum at WOT to seal the rings, et al. Thanks for posting the results, I wish I had that equiptment to dink around with, to offer a better option. Under cruise conditions, I don't believe GM intened the engine to be in a constatnt state of vacuum. This will probably wear out the seals quickly.
Old Sep 16, 2005 | 08:50 AM
QuickSilver2002
Originally Posted by IM QUIKR
QS,
I don't consider it a failure. It's not perfect, but it is also not a complete failure. What you don't understand is that you want a vacuum and some flow at idle (it will help seal the rings and keep the crankase clean) .... The boost seals the rings under WOT. A vacuum under boost would also be nice, but it is not required.
It is also hard to compare this with other setups, since nobody really knows what the CC pressure is with those other setups.
Old Sep 18, 2005 | 05:13 AM
Cscokd's Avatar
Cscokd
Could you guys comment on my setup (see link). I have a 1998 N/A engine with a few mods. I used a different check valve than the stock one. I removed the OEM PCV and replaced it with a heavy duty PCV from www.mcmaster.com part # 7775K52 "viton". I installed it close to the intake between the catch can and intake port.
My PCV Setup
Thanks for any feedback you might have. I've noticed a little erratic idle occasionally since installing this. Wondering if this has anything to do with it.
Cheers
John
Old Sep 18, 2005 | 09:18 AM
IM QUIKR's Avatar
IM QUIKR
Cheers
John
I know it sounds simple but did you make sure that the check valve allows air flows into the intake? Then I would make sure there are no vacuum leaks and recommend an IDLE RELEARN.
Did you cap the valve cover port on the pass. side front? Hard to tell fron=m the diargram. Do you have a fresh air source? The engine is expecting a specific amount of air coming from the PCV.
Old Sep 19, 2005 | 12:30 AM
Cscokd's Avatar
Cscokd
[IMG]
yes....arrow points toward the intake
didn't do this yet...will do a search for instructions
Did you cap the valve cover port on the pass. side front? Hard to tell from the diargram.
no...didn't touch this
didn't touch the air source going to the passenger side valve cover
Thanks for the suggestions. Let me know if I missed something. QuickSilver2002, my appologies for hijacking this thread.
John
Old Sep 19, 2005 | 08:15 AM
IM QUIKR's Avatar
IM QUIKR
Your sig does not say that you have a SC or turbo. If you are still NA I'd reinstall the factory PCV valve. Why? The PCV valve is a metering valve and if you don't need a check valve to prevent boost, then go back to the stock valve.
Old Sep 19, 2005 | 11:52 AM
QuickSilver2002
Make sure your fresh air source is hooked up in front of the TB, so the air can still be metered by the MAF.
I also agree that you should probably put the stock PCV valve in place. Without it, you have too much flow from the crankcase at idle and the idle air trims are probably maxed out. You have to remember that air from the PCV inlet bypasses the TB and confuses the IAC control.
If you want a vacuum on the crankcase at idle, you have to put some type of flow restrictor on the fresh air side.
Old Sep 19, 2005 | 11:55 AM
QuickSilver2002
Cscokd,
Old Sep 20, 2005 | 12:41 AM
Cscokd's Avatar
Cscokd
Thanks for the advice you two...my car is N/A and not SC or TC...I'll change back to the stock PCV and try it for a while. Since I did not touch the stock hose from the TB to the passenger side valve cover at the oil fill pipe, I should be ok there right? Do you think I should do an idle re-learn procedure on it? Seems since I installed my LGLTs my idle has been irratic at times.
John
Old Sep 20, 2005 | 08:17 AM
IM QUIKR's Avatar
IM QUIKR
Well now, since you have installed LTs you really should have a professional tune to help with the idle and get the most performance from the headers. Changing exhaust headers can make the computer think you're running lean so the idle will be effected. Put her on a dyno and get her tuned. You're gonna love it.
Old Sep 20, 2005 | 04:21 PM
  #33
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Pcv
Great Article
Old Oct 5, 2005 | 12:12 PM
  #34
QuickSilver2002
Disregard the results I posted above.
I kept thinking about my old results and realized that something was totally different now. The car previously hissed as I shut it down and lately there has been silence. I realized that I had lost most of my vacuum on the crankcase. After further investigation (including a compression test….) I found that I had a big open port in the side of my catch can (#2) where the plug fell out (duh!!!!).
I just ran a quick log again and the results were totally different. It runs at about 75kpa at cruise. It then holds a vacuum under boost until about 7psi and then it goes to about 103kpa. I’m still working on the SD tune in that area, so I have not pushed it to redline.
I think I’m convinced that a nice check valve would be worth it. I hate paying $100 for the krankvent valve, but it would be worth it if it really worked. I think the vacuum will hold most all the time if I only vent when slight pressure forms.
Anyone ever had one of those KrankVent valves in their hands. I would like to ask a few questions about how it flows…. I basically need a check valve that has very low cracking pressure and can flow a lot of air if it needs to.
If anyone knows of a source for a cheap vacuum regulator that would also be great.
Old Oct 8, 2005 | 08:11 PM
  #35
vertC6's Avatar
vertC6
A very good piece QS 2002, it has been very informative. I was reading this article about a dual krank vent valve set up, if you will read it and tell me what you think.
http://www.stealth316.com/2-krankvents.htm
On a side note, I am buying a c6 and going with a s/c with about 6psi. Would it not work well if I were to simply leave the stock PCV and run a hose off the valve cover through a one way by pass valve to a small breather. I believe this would maintain vaccum at idle and releave crank case pressure under boost. Thanks for your time.
Old Oct 10, 2005 | 12:12 AM
  #36
QuickSilver2002
Quick update.
I got the ET Performance KrankVent valves in the mail today. The cost was high, but it does seem to be a really good valve. I'm amazed how low the cracking pressure is and it also seems to flow a decent amount of air.
I replaced the solenoid on catch can #2 with it. The results are very good so far.
I made a few quick pulls tonight and it held a vacuum up to about 8psi and then it just went to atmospheric. This is better than I expected with the current setup (the restrictor inlet side is a known vacuum leak once in boost).
I've got a few more tweaks to make and should have a final design by the end of the week.
The best part of this is the added low end tq the motor has. The throttle is very crisp. I drop it to 3rd at about 80 and I loose all traction if I nail it all the way (that is with only about 6psi or so @4900 rpms). It pulls so dam hard by 6k that everything feels like it is starting to blur.
I can’t wait to get it on a dyno for the final tune and to see how much power she is making. I'm hoping to do that next weekend.
Old Oct 10, 2005 | 08:57 AM
  #37
vertC6's Avatar
vertC6
Thats great news, did you run both valves the same way that they illustrated on the web site? Or did you completely remove you PCV and put the smaller valve in place of it? I think I am going to try runing the valve with the PCV, and with the large valve, run it off the back of both valve covers to a T and then to a vented catch can. From what they said on there site, this should work well.
Old Oct 10, 2005 | 10:40 AM
  #38
QuickSilver2002
No, look at the original post and you can see exactly where I'm running the KrankVent valve. The solution described in their instructions will not work well on our cars (IMHO).
The original design of the valve was for big v twin engines and the concept as described on their website will not work on a v8. The valve is however an amazing check valve with extremely low cracking pressure and it works great as a one way venting valve.
