Pinning the crank will likely be worst part. It depends on your skills and then the tuning part (never underestimate tuning, your engine will thank you).
Mike
What is involved in pinning the crank?
Isn't the tuning handled by flashing with a handheld programmer?
Start by reading https://www.aandacorvette.com/supercharger_inst.asp web site. Tuning from handheld programmers is by most considered a means by which to drive to a qualified tuner. It is generic and not all engines respond the same, the $300-500 you will spend for good tune may save you thousands in long run.
I am an average , maybe sub average back yard mechanic...This spring, i changed my old dual intercooler system the the A&A single system. 30 hours on my ^@ back....I am glad i did it, but i had the old system to follow as a pattern....I would STRONGLY suggest you have it installed by a pro, and most important, TUNED by a pro....You must pin the crank. This is not a job for an average weekend wrencher in my opinion
Make sure you read my thread about cam bolts backing out...make sure you go in there and retighten them and relocktite them so you don't have the same problem I and many others have had.
I would say if you consider yourself an average mechanic then you need to let someone else do it. I consider myself pretty good and it was somewhat of a challenge to me. If you decide to do it yourself, Private message me and I will give you my number. I will walk you through any tough spots you run into. That goes for anyone else as well. If you need some help or have some questions just let me know.
What is involved in loctite-ing the cam bolts? Do you have to pull the whole cam out or do you just have to remove the front cover (and entire front end to get to it?) ?
there are 3 bolts holding the cam in under the timing cover and crank pulley. you have to remove the bolts put loctite on them and retorque to 14ft/lb.
Thanks. What all do you have to remove to get to this? Crank pulley? front main seal? Radiator? Steering rack?
Just looking for how long the job will take. I'm a newbie to cam work.
airbridge, and intake box, a/c condensor needs to be unbolted and tied up out of the way, radiator drained and removed along with the fan assembly, radiator and condensor subframe removed, powersteering rack removed, crank pulley removed, front main seal, timing cover, timing chain, and then the cam bolts.
