Custom engine bay pics?
Old Sep 8, 2005 | 07:46 AM
EFI-1's Avatar
EFI-1
Default Custom engine bay pics?
I'm looking for some cool engine bay pics from the FI guys....fuel rails, intakes, NOS set-ups, relocated coils, etc....I'm trying to get ideas for what I want to do with my phase III EFI-1 build-up.
Can you guys help a brutha out?
Old Sep 8, 2005 | 08:41 AM
EatRice's Avatar
EatRice
Here is one for you. This is the way my motor used to look. Hope it helps you out.
Old Sep 8, 2005 | 08:49 AM
b98's Avatar
b98
Old Sep 8, 2005 | 09:47 AM
vettewreck's Avatar
vettewreck
dave....where you been at buddy??? You getting ready to dump even more money into that money pit of yours?? LOL!!
Old Sep 8, 2005 | 11:46 AM
AVB's Avatar
AVB
Dude.. I think the hood bracket thingee's look freakin great. Where'd you get em?
Old Sep 8, 2005 | 12:04 PM
BLOWN'NC's Avatar
BLOWN'NC
All that going on and you focus on the hood brackets
Old Sep 8, 2005 | 01:05 PM
EFI-1's Avatar
EFI-1
Randy, great pic! That engine compartment rocks. I would like to do teh valve covers and coil-relocation for sure. I am looking into a good looking fuel rail set-up for the FFS equipped Vettes.....not sure if the FAST rails will work.
Mike, been busy getting my business off the ground and trying to figure out if I am going to move to Colorado. I am definitely looking to dump a few more peso's into the Z...need to finish my ICE, brakes, and now this TT. We gotta talk brutha....I'll drop you a line!
Old Sep 8, 2005 | 03:31 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Mine still needs a lot of clean-up done to it (radiator shroud, clean up wiring, etc.), but here's the gist of it:
I am using the FAST rails (obviously) but have run my own braided stainless to the rails. They use #8 o-ring boss fittings so I'd imagine that these rails would work as well as any of the other aftermarket rails I've seen, all of which are either NPT or AN tapped.
Old Sep 8, 2005 | 03:34 PM
babala65's Avatar
babala65
Old Sep 8, 2005 | 04:58 PM
EFI-1's Avatar
EFI-1
Sick pics guys.
DIY, what year is your car? Can I use that same fuel rail set-up with my 2003 Z06? Also, what TB are you running if you don't mind?
Old Sep 8, 2005 | 05:05 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Originally Posted by EFI-1
Sick pics guys.
I have a 2002 (C5). As far as I know, there's no reason you can't use these fuel rails on your car. You will have to figure out how to adapt the factory feed line into the rails as they are fed through #8 o-ring boss fittings. The easiest way might be to cap off the o-ring fittings and weld-on a fitting onto the rail that will just accept the factory feed line.
I'm using a stock throttle body, but I sanded it to clean up some of the casting and then painted it.
Old Sep 8, 2005 | 05:36 PM
EFI-1's Avatar
EFI-1
Cool. Thanks for the feedback. I need to figure a real clean way to get a bling'd out fuel rail system sitting on top of the motor.
To Custom engine bay pics?
