Fuel Issues
Old Sep 11, 2005 | 06:44 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
Default Fuel Issues
who sells torco additives on the forum, and are the results as good as race fuel alone? want to run on 104 octane, I read if you mix 320z to 10 gallons of 93 you get 104, is this correct.
Old Sep 11, 2005 | 08:55 AM
RoadRebel's Avatar
RoadRebel
Joel does!
jbsblownc5
Not sure on the mixing, he did post some analysis previous that Im sure is on his site.
Phil
Old Sep 11, 2005 | 09:36 AM
GR8-LIFE's Avatar
GR8-LIFE
Unless I'm misundrestanding, I doubt thats possible because the lesser octane plays a dominant role.
Take this situation. In a 20 gallon tank, mix 10 gallons of 92 octane with 10 gallons of 104 octane. You will definitely not get 98. You might barely get 95 believe it or not. Dont ask me how this works but i have heard that will be the result.
Old Sep 11, 2005 | 09:55 AM
Sack Rat TT's Avatar
Sack Rat TT
That is the way it works when mixing fuel.
Old Sep 11, 2005 | 03:04 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
But he's not mixing fuels. He would be mixing Torco with fuel.
99 C-5 F1C VETTE: This will get awefully expensive for you. Its gonna run you around 55 bucks to fill your tank to 10 gallons.
Old Sep 11, 2005 | 04:31 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I sell Torco..
I mixed 10 Gallons 91 octane with 1 32 oz can of Torco, and the Lab told me it was 96.5.
If you mix it with 93, I imagine it would be around 98.5.
Mix 5 gallons of 93 with 1 can of Torco, and you "should" be around your target goal. I have only had lab tests done on the above combo, make sure you check KR when trying your own mix!!!
Let me know!
JB
To Fuel Issues
