Nice Install. I am doing the NX Dual Nozzle and also got a TNT Power Ring.
Any tips on the ring install?
Gary
My kit was from an F body. So my solenoid mounting and the throttle body wire harness left me little room for the nozzle on the passenger side. I actually got everything but the passenger side nozzle mounted up. Then relocated the passenger side nozzle about 30 minutes on a clock closer towards the driver side nozzle for good clearance. Before that though, I had to file the cast ring on the outer edge of the throttle body for the power ring to slip on, even with the light tapping of a soft hammer
what kind of kit did you install? I am installing a nx wet kit with the gen x 2 package. I am having a time placing everything. I like your console. Are you starting off with a 75 shot jet?
rod
rod
TNT F1 kit (75-125hp rated). I just took my time to place everything where it wouldn't clutter the car up. Plus it was more for an F-body, so some slight changes in fitament needed to be made. I was going to go with a 10lb bottle swap, until I saw all of Robert56's 15lb bottle installs Thanks forthe console, getting the angle and placement right was a pain. I may end up redoing it anyway for cosmetics
