which cr ??
Old Sep 13, 2005 | 05:20 PM
MRC5's Avatar
MRC5
Default which cr ??
i'm going to forged the engine ,but i still dont have a clear idea a bout which piston and head. what is the good compression ratio for high hp and 14 psi. with p1 procharger.
* flat top piston -8.6cc with stage 3 ls6 heads. = 8.6:1
* flat top piston -2cc with stage 3 ls6 heads. = 9.1:1
my goal is 600 wrhp .
what do you advice me ?
Old Sep 13, 2005 | 06:45 PM
Z06 Tom's Avatar
Z06 Tom
I'll be doing the same thing this winter. I'm thinking about a 383 stroker.
Old Sep 13, 2005 | 09:03 PM
SS930's Avatar
SS930
I don't know what they use to calculate static CR over there, but we must use WAY different formulas over here!
I'll assume you are using 72cc heads, .045 HG, and coming out of the hole .005" (just basic assumptions). Based on these numbers you'll have about 9.1:1 CR using the -8.6cc piston. With the second -2cc piston you'll have about 9.75 :1 CR.
Given the 2 choices, go with the -8.6cc combo.
Old Sep 13, 2005 | 09:49 PM
blu00rdstr's Avatar
blu00rdstr
LS6 heads have 64.5cc chambers. http://www.smokemup.com/tech/ls1.php
Keep in mind most forged pistons are only rated to 15psi boost. At least get the pistons ceramic thermal coated to keep heat out of the piston. Mahle pistons come coated, in some cases coating is a $300 option.
I'd recommend 9.1:1 CR as you'll have trouble getting enough boost from the P1SC.
Old Sep 13, 2005 | 10:05 PM
mdhmi's Avatar
mdhmi
With that setup I would try to get the CR around 9.5:1.
Haven't found a complaint yet with the AFR 205 heads.
Mark
Old Sep 14, 2005 | 12:58 AM
FRC Tom's Avatar
FRC Tom
Al. heads don't like much more than 12:1 CR.
With a CR of 8.6 and 14 lbs of boost you are looking at a ECR of 12.017:1.
Old Sep 14, 2005 | 01:08 AM
blu00rdstr's Avatar
blu00rdstr
You know, I never did understand how to calculate the whole ECR thing when factoring in lopey cams.
Old Sep 14, 2005 | 01:51 AM
FRC Tom's Avatar
FRC Tom
sqrt((boost+14.7)/14.7) * CR = ECR (effective compression ratio)
Old Sep 14, 2005 | 07:07 AM
SS930's Avatar
SS930
I realize what size the factory LS6 heads are. I made the assumption of 72cc based on him saying they are "stage 3" heads. I don't think either one of us can say what his heads are... only speculate.
BTW, I could be wrong about this but I don't think Mahle pistons are 'fully' coated. I believe they only come with an anti-friction coating on the skirt (which is somewhat common with performance pistons). I do not believe they have any type of thermal barrier of the face.
Old Sep 14, 2005 | 07:34 AM
MRC5's Avatar
MRC5
thanks ya all for replys..
patirot 6 liter heads stage 3 72 cc with -2 dimond piston ..= close to 9.2:1 .. i thing this compression ration is good for p1 .
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Sep 14, 2005 | 07:58 AM
SS930's Avatar
SS930
Your calculator is flawed. It doesn't allow you enter a negitive number for the deck height. The LS1 pistion typically comes out of the hole about .006", you can't enter this in your calculator. Also, most HG are about .045", but some are .055".
Based on the piston coming out of the hole .006" and using your .055" HG with the -2cc piston you get 9.47:1, 9.67:1 with the .045 HG.
Old Sep 14, 2005 | 10:57 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Cc
My heads are 72 CC and have 9.1:1 Compression I have a Procharger and 625 RWHP
Old Sep 14, 2005 | 02:39 PM
MRC5's Avatar
MRC5
whats ur piston and HG cc. ?
Old Sep 14, 2005 | 03:14 PM
roythomas's Avatar
roythomas
Mark
should leave some com for instant grrrrr on the street .. ya !!! you can't run as much boost but it's tuff getting 1000 hp down to the ground anyway
Old Sep 14, 2005 | 03:24 PM
Shinobi'sZ's Avatar
Shinobi'sZ
He's right. You either have to subtract it from the HG or using another CR calculator..besides Ross
Oh and by the way, I have used the same setup for 3 different power adders now (SC, TTi, and PTK).
I utilize -2cc valve reliefs, and use the CC volume to reduce compression ratio...with a pinch of extra HG thickness (Cometic MLS .065"). It has been a good recipe so far.
My heads are LS6 77cc (West Coast Cylinder Heads..A&As guy). I could have used GM MLS HGs (.054" compressed) and my CR would have been 9.2:1..but went with a slightly thicker HG (my deck height is .014"..due to 6.126" Lunati Rods and Diamond Piston Combo..oh and the block was decked .004"). So my CR is 8.94:1. Going strong...at least this morning it was.
Nice thing about using flat tops with valve releifs is that if you ever want take everything back off...all you need to do is swap the heads for some stock ones and your back to your stock CR....approximately.
Old Sep 16, 2005 | 07:42 AM
MRC5's Avatar
MRC5
good info. thank ya all.
To which cr ??
