D1SC vs. F1R
St. Jude Donor '05-'06-'08
D1SC vs. F1R
I am debating to switch my D1SC to a F1R....... Will like to get some input from owners that have had the D1SC and switch to a F1R.
Former Vendor
St. Jude Donor '06 & '12
Its the difference between a gradual spool up and a swift kick in the nutz. The D1 comes on kind of weak but spools up hard and pulls all the way to the top. The F1R comes on strong (violent) and pulls like a freight train till you let off the throttle (or you pi$$ your pants)
I just noticed on ATI's web site that they changed the step-up ratio on the F1R from 5.0 :1 to 5.4 :1. That should make for an even bigger difference in power ramp-up. I don't see the F-1C on their specifications page any more.
Sean
Sean
Sean
Sean
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What would you have to do to your engine to run an F1? Could you do it on a small cubed forged block or do you need a bigger one?
Former Vendor
With an F1R you MUST have a forged motor and Run 8 rib pullies.
Originally Posted by AMERICAN_HP
I have it on a forged 347ci motor with no problems at all.
D1sc/f1r
I have a D1SC in my stroker Motor (383), with the D1SC I get 12 Lbs. with a 3.85 Pulley.
If I get the F1R, I would adjust the shift points down about 300 RPM......I know the pulleys on the F1R's are also different size than the D1SC
The F1R, good God.... 8 rib for sure, and maybe an extra support to prevent bracket flex. Is this a street car? The F1R, even at idle sounds like a 747 taxing for take off. I had one on my drag car (68 Camaro 10.5w w/540cid) It ran in the 8's, mild cam, head and blow through carb, at only 15 lbs (Which came on as quick as a Roots or Twin Screw style blower...NO LAG).. Very serious blower. Good Luck...
Life Time NCM #2196
Former Vendor
Thanks! Which heads are you using? How much boost? How much HP? Sorry for all the questions but I plan on going with FI in in the next month or two and want to go forged at the beginning of next year to increase the boost. I'm going nuts right now trying to figure out which one to get. I'm kinda waiting to see what the KB is gonna look like price wise.
Since I have 100 octane avail to me I was thinking about trying it with that as well.
Former Vendor
Originally Posted by peter pan
Mike you better get one soon, when Jeffs upgrades his car I want to get his for my car
True
Its true.....The good thing about this is that I have FIRST BIDS on this F1R...........................
