C5 T-76 Single turbo kit
Supporting Vendor
Originally Posted by QuickSilver2002
Have you checked it on a car with the newer style ABS block. Looks like the car you have it on is the older style. Hard to tell if it would be a problem from the pics.
I might be wrong, I know the 97s had it in the back and mine seems to be different than the pics, but I can't tell for sure.
Originally Posted by ForceFed HP
what year did that start??? the one we have it on is a 2000. thanks for bringing that up. that is a good thing to look for. now to find a newer vette.
Supporting Vendor
Where will the air filter be?
Supporting Vendor
I changed my post becase I wanted to look at mine first.
it comes off to a 45 degree angle (to clear the abs module) and then has a filter on it.
The original ATI kit got air from behind the radiator (it was the worse possible design). It was integrated into the fan shroud. Everyone who moved it to the front noticed a huge difference in charged air temps.
An open cone might not be as bad, but getting cool air from up front would be much better.
The air is pretty hot back there.
Supporting Vendor
thanks for that picture. it looks like it will fit. i have a friend coming buy tomorrow with a vette with that abs to test it on his car so i will definetly know if it will work.
Supporting Vendor
Originally Posted by Watch22
Will this kit mate up to the stock exhaust locations?
the down pipe goes down and splits into two 2 1/2 inch pipes and does connect to the stock locations.
#33
1 Post
Niece work guys, it looks like a bit of tight fit but then there isn’t much room in engine bay. With your projected prices you will have a strong seller.
As mentioned above the air inlet location may be a source of concern to some. Keep up the good work and looking forward to numbers.
Mike
Mike
#36
Supporting Vendor
Originally Posted by Oo Joe 24 oO
what are the charge pipes made out of, mild steel or stainless? Will this be a direct fit or will it require any cutting? What is being used for fuel/timing adjustment?
#37
Supporting Vendor
Originally Posted by Earl H
Where are you going to mount the wastegate?
the waste gate will come off at a 90 degree from the collector at the turbo and will feed right back in to the down pipe. we will have pictures of this next week.
#40
Yeh I also cant wait for this kit....I want some forced induction and I hate half the blower setups where power falls off up top...Turbo is the way togo
