smaller head bolts
Old Sep 25, 2005 | 09:24 PM
denscor's Avatar
denscor
Default smaller head bolts
The smaller head bolts how important are they? I striped one out!
Old Sep 25, 2005 | 10:26 PM
SS930's Avatar
SS930
Very!!!
Old Sep 25, 2005 | 11:06 PM
denscor's Avatar
denscor
can it be fixed with heads on car or do I need to take heads back off?
Old Sep 25, 2005 | 11:32 PM
RED99's Avatar
RED99
That's not good. You will have to take the head off. You are talking about the bolts that holds the head down to the block right? You may want to talk to some engine builders first before you try to repair it. There is several kinds of thread inserts, and since there is a lot of torque on those bolts, you want to insert that works the best. Good luck, and sorry to hear about that.
Old Sep 26, 2005 | 12:01 AM
denscor's Avatar
denscor
the m8 ones not the bigger ones m15
Old Sep 26, 2005 | 02:48 AM
Dixit's Avatar
Dixit
Its not that big of a deal to remove the M8 ones. If you can see the bolt, you can remove it without taking the head out. All you have to do is drill a hole dead center on the broken stud, then put in an extractor bit and thread it out. But key is drilling it dead center.
Dixit
Old Sep 26, 2005 | 11:08 AM
RED99's Avatar
RED99
Dixit
He said he STRIPPED IT OUT, not broke it off.
Old Sep 26, 2005 | 11:18 AM
kromberg's Avatar
kromberg
Important, but not critical. They are only torque to 22# and that is mainly to keep blow by and vapors in the lifter area. I would try the vise-grip loosen method if you can get a set on the bolt head. If you can not, use a dremal to grind two parallel flat spots and use a smaller wrench. If you use the dremal, tape up the intake ports of the heads!!!!!
Keith
Old Sep 26, 2005 | 11:37 AM
Dixit's Avatar
Dixit
Sorry. It was 3am when I posted that one.
Hahah, stripped out, well head definetely going to have to come off and you going to have to retap that to a slightly larger thread size.
Yea those are only 22ft lbs, did you torque it more than that or just got unlucky and it stripped?
Dixit
Old Sep 26, 2005 | 11:48 AM
M_T_0's Avatar
M_T_0
They are not as important as the m15's, if I were you I would try to get an ARP bolt/stud (they have much deeper threads) and see if I could get that to pull 22fp and be done with it.
if this were the m15's then you would have to helicoil the block which is a PITA.
ARP's are a B!^@# to put in but they do have a much better grip in the alum. block.
More Than Zero
Old Sep 26, 2005 | 12:06 PM
denscor's Avatar
denscor
just got unlucky I troqued all of them at 22 ! I'm using ARP head studs.
Old Sep 26, 2005 | 12:13 PM
kromberg's Avatar
kromberg
WOW!!!! I have never heard of stripping an ARP nut with 22# of torque
Keith
Old Sep 26, 2005 | 12:18 PM
denscor's Avatar
denscor
I know its in the block,heads have been off before I think they had something to do with it .
Old Sep 26, 2005 | 12:28 PM
QuickSilver2002's Avatar
QuickSilver2002
So it was stripped before you even put the stud in?
Did you clean up the threads with a tap before you put in the stud? (You can make a cleaning tap out of the old bolt)
Oh, that sucks. That is exactly why I would never use regular throw away bolts on the heads.
Old Sep 26, 2005 | 01:05 PM
denscor's Avatar
denscor
cleaned and everything! It sucks ! I going to get a helicore kit and fix it. Someone local told me it was not important but gm would not have put them there if it wasn't.
Old Sep 26, 2005 | 01:20 PM
Shinobi'sZ's Avatar
Shinobi'sZ
You still have to drill it out to put a helicoil in it smart guy!
It will be easy to repair with the head on the vehicle, I would not suggest trying to TAP it because it is aluminum...althouh I have tapped the head before and used a stud in place on the exhaust manifold bolts...but that is only because I would have to pull the head off to drill it properly and insert a helicoil to repair it right...there is not enough room to do that with the head on the motor in the engine bay.
The little bolts are much easier. The thing to be most careful about...is not drilling it to far out or if using a stud make sure you just snug it up...a little past hand tight...nothing more or you will break the head.
Old Sep 26, 2005 | 02:53 PM
M_T_0's Avatar
M_T_0
OH that sucks big time, sorry to hear that. In this case I would helicoil it. use one of the other bolt holes to get the depth right and I think that it will be easier to leave the head on for those as a guide (I think).
as an alternate you could try to adhear the stud in place with the adheasive that GM recomends for repairing the block bolt holes (will only work with the studs and only if you plan an leaving the studs in the block)
anyway good luck.
More Than Zero
To smaller head bolts
Old Sep 26, 2005 | 03:42 PM
Shinobi'sZ's Avatar
Shinobi'sZ
I just read you were using Head Studs...please tell me that you didn't TQ the head studs in......hand tight or very little more is all that is needed when placing the studs in the heads.
I tq'd the big nuts down to 85-90lbs.
Old Sep 26, 2005 | 07:21 PM
denscor's Avatar
denscor
no head studs were put in hand tight. I think thats has been my trouble all along.Bolt was striped
Old Sep 26, 2005 | 11:24 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Cool...drill it..helicoil it....put stud back in...call it a day. Might as well re-tq them all while you are in there.
