rpm window switch install
Old Sep 30, 2005 | 01:25 PM
Scooter1964's Avatar
Scooter1964
Default rpm window switch install
I am having trouble finding where to hook up my tach wire. I know the book says no10 pin white wire on right inner fender well but there are a thousand wires there and I am just a little over whelmed. Does anyone have pictures of this install or a link to one. hopefully i am in the right forum for this question. I have done numerous searches on the widow switches themselves but can't seem to find what i am lookinig for. I am expecting a NXexpress kit Monday and want to install as soon as possible. I would appreciate any comments or helpful suggestions on this as well. Thanks
Old Sep 30, 2005 | 03:04 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
all the wires are numbered on the computer. Just find the wire, it is white and tap into it. It sin't very hard, i would take a picture for you right quick if you really need. PM with an email an i will go find it for you
Dom
Old Oct 3, 2005 | 12:07 AM
Scooter1964
Default window switch
do you tap into the wire up under the glove box or outside near the battery? thanks
Old Oct 3, 2005 | 12:25 AM
Mr. Big's Avatar
Mr. Big
right at the computer. Take off the front pass side tire, then take off the wheel well cover and there is the computer. very easy to get too. Tap the wire and run it to the window switch. 30 min job at the most.
Dom
Old Oct 3, 2005 | 01:42 PM
Scooter1964
Default thanks
thanks . sounds pretty simple I'll give her a shot.
Old Oct 4, 2005 | 07:28 PM
Scooter1964
Default still loking for rpm switch wire?
Does anyone have a picture of where to hook up the tach wire for an RPM window switch? I have asked and gotten lots of help but still not sure. I took the inner fender well off to look at the ecm but there is more than 1 white wire and I cannot find numbers anywhere if there are any. Sorry to be a pain but can someone please help. I am from Missouri so someone will actually have to show me.lol Dumb joke I know! Thanks in advance for any help.
Old Oct 4, 2005 | 09:48 PM
RoadRebel's Avatar
RoadRebel
unhook the PCM connector (7mm nut driver) and get a look at the connector body and you will see the #s .
Phil
Old Oct 4, 2005 | 09:53 PM
Scooter1964
Default rpm switch
there are 2 conectors correct? are the numbers on the ecm? I didnt see anything on the plugs.
Old Oct 5, 2005 | 06:17 PM
Mr. Big's Avatar
Mr. Big
no, they are on the plug, you may want to remove the grey plastic covers and you should be able to see all the numbers.
Old Oct 5, 2005 | 09:55 PM
Scooter1964
Default thanks
thanks i'll try that.!!
To rpm window switch install
