First off, this is not a slam, Torco is a great product and I'll continue to use it.
I had a couple of cans of Torco that I bought about year ago. I have not been using it because I was not getting any KR at all. I decided to use it up and dumped a can into each of my last two tanks of 91 octane.
I have been logging a lot of data lately since I have been working on my main VE table. On the two tanks that I put the Torco in I saw a huge increase on KR (up to 15 degrees) in the 4000 to 5000 RPM range (mostly clustered around 4400 rpm). Last night I ran the car down to 1/8 tank and filled it up with 91 octane (no old Torco this time). I ran the car for a 2 or 3 miles while logging data and the amount of KR had dropped to less than 3 degrees, all at 4400 rpm. I continued driving for another 10 miles or so and then ran it up from 3000 RPM in 2nd gear through the top of 4th gear at 6500 RPM and got no KR.
Is it possible that the chemicals in Torco, as they age, could actually induce knock? If so this is a really good reason not to exceed the recommended shelf life of 6 months.
I need to log some more data this weekend when it warms up. The temperature dropped 35 degrees today so if I logged data now it wouldn't be a valid test since it is so much cooler.
You don't want to let Torco sit around very long. This product is VERY hydrophlic. MMT (methylcyclopentadienyl manganese tricarbonyl) which is what makes Torco "work" as an octane booster, I believe it is easily contaninated which should disrupt its performance as well.
My advice for those of you who use Torco would be to "use it or loose it!" Don't let it sit for more than a couple months. If you see the color changing as you use the container, disgard it (in a proper manor because MMT is a pretty dangerous organometallic compound). BTW, you DON"T want to get this product on you... there's some really nasty stuff in it so wear gloves when using it
I have experienced it going bad.....but I also stored it in my garage (110+ degrees) on concrete and let it sit for several months without using it. The color became "milky" and it was quite obvious that something had happened to it.
I now store it in a small closet in my house (I know, I'm crazy right?.. ) and haven't had any problems since.
I've been storing mine in my basement, which is cool of course. Is it OK as long as it's still clear?? I've still got six cans left that are close to a year old.
It maybe cool in your basement, but it's likely humid. Because of the hydrophilic nature of the components, I don't think I'd use it if it's a year old. You're probably better off being safe rather than sorry. I suspect even Torco suggests a limited shelf life.
Thanks for all the replies. I should have known better than to use it. The last stuff that I used was from a friend's (Yano) new unopened 5 gallon can. It was yellowish in color, not clear.
That is awesome of JB to offer a deal to those who have old Torco!
