I am in the process of installing the new STS twin turbo kit on my 2003 Z06. I was wondering if anyone has any first hand experience where to install the Fuel Pump Booster. It looks like a little amplifier...
i mounted mine in the rear drivers side corner compartment so its closer to the fuel pump with a 30 amp relay, my battery is also in the rear so there is no voltage drop. this is the best and only place to mount it for true results. if some one can post picts for me ill e-mail my set up
I mounted mine behind the LF tire wheel well next to the Alky pump.
Then covered the wires to the pump with that wire loom stuff and passed it through the rocker rail back to the fuel pump.
