What am I missing???
The keys to making the insane HP levels are : (boost, boost and more boost + )
- Solid sealing surfaces (factory designed with boost in mind) there are a lot of bolts holding that head on
- Very low static compression (a real dud in off boost)
- ring positions designed specifically for boost
- oil squirters and a galley in the pistons (to cool the pistons in high boost)
- a boost capable ECU
- A head with 4 valves per cylinder and double over head cams that flows great and revs like a ****.
And don't think for a second that a 2jz or any other import motor running at that level of power will not pop. It happens all the time. One mistake in the tune and that is it.
Bottom line, boost is the replacement for displacement. It is actually a heck of a lot easier to make usable power with an lsx motor.
Just look at it this way, A stock 3.0 na supra made 160 crank hp.
dam man you are good. I rechecked the original post (at Supraforums) and yep, the motor is a stock bottom end 2jz-gte motor, not the 2jz-ge that I originally thought. Even though, that's some killer ETs and HP from 'only a 6 cylinder'
Here's the link to the vids ( 9-second run ) if anyone is interested in seeing an import luxury car go 9.xx @143...oh yea, it's a 6-speed also. I'm not trying to turn this into a Toyota forum, just thought that other gear heads would be interested in seeing what a little boost can do.
I was always a hardcore american V8 guy until I bought a honda sport bike. Man there is just something about a low stroke engine shrieking to 15k RPM that cant be compared to. Its a compeltely different ball game.
You guys might want to take a damn hard look at the engines used to push the quickest cars on earth... Top fuel engines make thousands of hp and I don't see any in-line 6's or tiny stroke engines in those things!!!
It's all about the amount of air the engine can flow throw it, the more boost that can be applied, the more air will be crammed into the cylinders, the more power the engine will make. The 2jz-gte was designed from the factory to handle huge cylinder pressures, the LSx engines were not designed to run any boost. If the LSx block, heads, mating surfaces, and rotating assembly were equally built from the factory, you'd see LSx engines running 40 psi too. Generally speaking, bigger engines will always make more power given equal boost with all things being equal. With enough boost smaller engines can behave like larger engines (although with a couple drawbacks). In this case, the larger LSx engines were not designed to handle the kind of pressures the 2jz-gte can, therefore the 2jz-gte can perform like a larger engine by being able to handle almost 2x as much boost. It has nothing to do with in-line 6's being a better engine than V8's.
Take a look at this thread and look at #21 http://www.supraforums.com/forum/sho...d.php?t=253322
"21. 9.46@143 Dave Henry Innovate Motorsports Auto NA-T Stock NA engine"
For the lazy
This motor had a stock (unported) head, stock bottom end, 264 intake cam, stock exhaust cam, thicker headgasket and ARP head studs... he was running 28 psi and 150 shot.
First, as already mentioned, there are two cylinders and con. rods between every main bearing on a V8, versus 1 on some inlines.
Second, both of these pistons and rods are pushing down on the same journal at about the same time:
Cylinders 1 and 2, 4 and 3, 6 and 5. (18436572 firing order)
Even at 1500 horse on a big block, main bearings that are somewhat curved instead of flat are often used to keep from wiping out the bearing edges when the crank bends enough to no longer sit flat on the bearing.
At really high horsepower levels, cranks are replaced as a part of scheduled maintenance whether they show flaws or not.
As you said though, other things are the limiting factors with our Corvette engines at this point.
Just hashing theory with you.
first off the EVOs 4G64 can easly handle 2.3bar on a bone stock engine, and so can its turbo, but only till about 6K then the turbo runs out of puff! and these things run a 8.8-1 comp. ratio! not exactly low!!
i remeber the old Ford Cossy days! guys used to drop them down to 7.0 to 1 and then turn the boost up to over 30psi! they made 500bhp on stock bottom ends (cossworth did a real good job on them) but they lagged like a b*ch! but thats not the case these days with high compresion and but with more power!
as people have said, it whats right for you! taking it to exstreams, the thought of a 500bhp 2.0ltr four pot (never mind V8) in a 500kg (1100lbs) lotus seven replica is just crazzy!!! but a twin turbo LSx making 1000bhp in a 3500lbs car is not THAT mad! but truck guys would laugh you out the building with your little torque figures compared to what they get!!!! each to their own!!!
thanks Chris.
PS. very good point about its what you do with it more than what you have!!!!
Hope that makes sense...
You were comparing it to the 8 cylinder @ 6K .... and making point about lots of TQ for the vette on sudden stoppage. Suddenly you jump over to comparing TQ with Free HP ?????
What gives ?
Good points .... does anyone make a straight 8 ? That should be the monster mash ... if it had 6-7 liters and could be made to fit inside a vette.
Straight 8 would be insanely strong - only thing is that you'd be able to change cylinder #8 while sipping your slurpie, because it would be sticking out past the centre console - no radio or climate control for you!
But, 10 inches is huge .... will never happen.
J/J.Last edited by bernrex; Nov 23, 2005 at 11:40 AM.
