Need Help With Tac Output Wire....
Old Nov 3, 2005 | 07:47 PM
texfire's Avatar
texfire
Default Need Help With Tac Output Wire....
I have a 99 C5. I'm installing a nitros works system with a RPM window switch, and WOT switch. I have all the wires figured out, except which wire is my factory tach output. Not sure where to look. Any help would be great! Thanks.
Old Nov 3, 2005 | 08:26 PM
AVB's Avatar
AVB
Search Results
Old Nov 3, 2005 | 09:58 PM
RoadRebel's Avatar
RoadRebel
That location is awesome if your mounting the RPM switch inside the vehicle. I also found that if you use a test light to ground and probe the white wires you will see the tach move when you hit the right "white wire". If its the wront one some other light will turn on. I think the other whites are emergency brake and skip shift.
If you mounting the rpm under the hood just snag the white wiref rom pin 10 on the pcm.
Phil
Old Nov 4, 2005 | 06:46 PM
texfire's Avatar
texfire
Phil
My pcm has no number 10 wire in that spot. it is blank. The only white wire is in the number 3 spot.
To Need Help With Tac Output Wire....
