Help Needed!!!
Nov 5, 2005 | 04:54 PM
Help Needed!!!
P 1220 & P1221.
Codes will NOT clear. Car stays in reduced power mode and is undriveable. Has happend a few times in the past, but was very random. WHAT DO I DO???
Nov 5, 2005 | 05:16 PM
P1220 TP Sensor 2 Circuit
P1221 TP Sensors 1, 2 Performance
Looks like the TP sensor(s) is cooked. I'll look up more in my service manual.
Nov 5, 2005 | 05:18 PM
I figured it's something to do with the TPS, the throttle body itself, or perhaps the MAF. Any help would be appreciated!!!
Nov 5, 2005 | 05:25 PM
THe throttle position sensor is actually 2 sensors in one. One holds high voltage with the blade closed, the other zero volts closed. One drops voltage as you open the throttle, the other increases voltage. P1220 is set when one of the two isn't operating within spec, and p1221 sets when tp 2 disagrees with tp 1 by more than 7.5%. Long story short - you need a trip to the dealer or a service manual or both. Good luck.
Nov 5, 2005 | 05:48 PM
Happened to me once. The TP wire was unplugged.
Nov 5, 2005 | 06:05 PM
Quote:
Will double check that area. Anyone got a real good pic of that area by chance?
Nov 5, 2005 | 09:41 PM
I see what the problem is. Your ETC is on the wrong side!
Nov 6, 2005 | 02:04 PM
Pull the TPS and see if there's moisture in there.. clean/dry it.
Arnel
Nov 6, 2005 | 02:44 PM
Quote:
Arnel
Will do. Thanks for the suggestion.
Nov 7, 2005 | 10:10 AM
Unplugged the TPS sensor, cleaned it up and plugged it back in. Seems to have solved the problem. Thanks for the direction guys!!
Nov 7, 2005 | 05:52 PM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Quote:
Wow, congradualtions Greg, sorry we didn't seem to come up with that when we were up there.
Chris
Nov 7, 2005 | 07:09 PM
Quote:
Chris
Yeah, you guys were like **** on a bull.....useless. Eat my pizza, drink my beer, and ignore my car... Man with friends like you guys....
On a serious note, what's up with Randy? Haven't seen him on here lately.
Nov 7, 2005 | 08:51 PM
Randy's banned for pickin on jon....and didn't we at least look at this connector?
Chris
Nov 7, 2005 | 10:30 PM
No, you didn't.
When Jon leaves here shortly to go join the 69 Camullet forum, will they let Randy back?
(I have just unwitingly hi-jacked my own thread!
Nov 7, 2005 | 11:09 PM
No, you didn't.
I guess we re-did the throttle body plug, and found that messed up plug wire, and were over confident, sorry abou that.
Randy most likely won't be back....not without a few appologies from what i understand.
Nov 8, 2005 | 08:57 AM
Wow, so Randy has become the Forum's T.O. Cool...
Nov 8, 2005 | 11:55 AM
So... was there moisture in the TPS? There was on mine.
Nov 8, 2005 | 11:57 AM
Didn't see any, but the the accordian insulation on the plug was all bunched up on one side, causing it to pull loose. I cleaned it up and plugged it back in, and it seems good to go.
Nov 8, 2005 | 12:01 PM
Cool... Glad things turned out to being a simple fix.
