383 stroker with maggie
Made 435 rwhp at 7 psi, but after 6 months, ring lands are broken on 3 pistons.
I want to rebuild this and try for mid 500 rwhp. (Closer to 600, but if NOS is needed then so be it)
Is it worth going with one of the econo 383 kits?
I am looking at rods and pistons anyhow.
Anyone have good reults with the Eagle or Scat stuff?
How about rod length piston height and cam recommendations...
TIA
Eagle is just fine.
382 all stroke with a Mag, Cartek got 567/567 to ground. Torque as flat as an EKG chart.
Set aside funds for a better fuel system as well.
What boost are you running? CR? Any meth or other stuff?
What did you do for fuel?
I'm in Miami and until I get this one done, my son is in the loaner (My 03 Z06)
So you see the urgency...
I use Progressive engines in Miami for honing, balancing, etc. They are a full race shop and know all the tricks. I have ALL the measuring tools, etc. left over from when I built race engines in the 70's.
I'm just not up to snuff on the LS stuff (yet)
Have a set of Dart 225's coming
I use Progressive engines in Miami for honing, balancing, etc. They are a full race shop and know all the tricks. I have ALLl the measuring tools, etc. left over from when I built race engines in the 70's.
TIA
Esp. with the meth on it.... Mine's running at 5#'s boost and about 400HP. Can't imagine my engine taking a dump with those numbers
I don't drive this one, so I don't know (yet). There are no signs of detonation or anything else.
Piston tops, combustion chambers and plugs all look just fine.
I've been researching and it seems that this is pretty common and many have even put many more miles on motor before finding out.
In some cases the bore gets damaged, but probably not in this case (Need more inspection)
Mark
I've been searching on some other forums...seems like some have had trouble with the Eagle cranks. Anyone know if this has been resolved?
Pistons are starting to look like Diamond or JE
Compstar rods are at the top of the short list (at the moment). I am not 100% comfortable with offset rods.
Just making sure you are not fixing something that is not broke.
I think that it was broke...
Outside of the smoke, the car ran fine. It revved to redline with no noise and still pulled hard (Well as hard as 435 rwhp with broken lands can pull
)I bought the car 36k on it. Probably hard miles from what I can tell, but the price was right and it has ALL the nice creature comforts.
A nice 600+ rwhp forged engine is what this baby needs, but on a DIY budget.
I had no time to play with it, so a local tuner installed the Maggie, another shop installed the clutch, and on and on.When the engine began to smoke, I decided that I needed to get involved and I am glad that I did.
Outside of the engine problems, here is what I am dealing with.
The front crossmember was loose on one side as well as some other fasteners.
The crank pulley wobbles (removed and pinned by someone during the maggie install)
The flywheel was never re-surfaced. I paid for that during the clutch install. Also, 1 of the clutch bolts was not OEM.
The front leaf is de-laminating, causing the front end to sag.
It goes on and on...
Here is the short list of repairs that I am doing...
Replacing all 4 wheel bearing\hub assemblies.
Slotted/drilled zinc rotors all around with Hawk pads.
Complete Z06 suspension..springs, sways and 06 shocks from Fred Beans
Tranny repair with all the stuff from RPM
And of course the engine and fueling, etc.
I don't want to know what all this would cost if I took it to someone GOOD, so I'll just have to bite the bullet and do it myself. Actually, my son and his friends have done most of the work so far. I've been playing shop foreman...
Anyone willing to share some knowledge or thoughts?
Please do...
Please do...
I would use it and some diamond or JE pistons on a low budget build.
Been there and it looks good.
I don't know if it's a typo, but they seem to have a very good price on the Callies as well.
I'll call and find out whether there are any major issues with the Eagle.
Also whether they can be used with 6.125 rods.
I'm looking at rotating weight, pistons and con rods. Anyone use the Compstar rods? Scat or Eagle?
Any specs on weight? quality?
I read that the Compstars are true on center rods while the other 2 are SBC and have an offset.
I am a little concerned about the distance from the top of the piston to the top ring. I believe the Diamond's are at .210 and .240 for off the shelf pieces. (p/n 11504 and 11503) Not sure about the JE's
In my case, more is better.
