From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Originally Posted by 99Z51R
Have sheet but no way to scan it, torque was 450 @ 2500, and peak torque (497) was at 3500 rpm and stayed flat to about 5500 and started to fall off a little, HP was a steady climb all the way to 6400 where he shut it down.
In all honesty I think a nice set of LS6 heads with a little bit of work would be the best set-up with the mag cam also. I bought the FFHP heads because of a special and they are suppose to be an LS6 "style" head. I will try and dig up flow sheets.
Thanks I looked at FFHp's site. They have the specs on a Stage 2 which they say is an LS6 head.
Interesting that hp did not fall off. There may be more left in it, if you can keep the heat down.
