I get this code every once and a while. Service ABS, Service Traction Control usually comes on afterwards. I clear the code an I am good for a couple more days. Is this something that my tuner can tune out, or do really have an issue.
Its the electronic brake/traction control module relay. It is integrated into the module and is not servicable. There is some wiring to the module that needs to be checked before replacing the module. First I would pull the main connector and check for corrosion and reseat it and see if it goes way.
