trapp speeds?
Old Nov 26, 2005 | 01:12 AM
brandon1566's Avatar
brandon1566
Default trapp speeds?
I have a 97 c5 auto with stock 2 73 gears rpm stage 5 trany 2600 stall A&A p1sc single intercooler kit and borla exaust no headers. what should my trap be I am at 118.76 is best so far on street tires. does that sound about right? The blower has the 410 pulley i am making 447.7whp
Old Nov 26, 2005 | 01:18 AM
mdhmi's Avatar
mdhmi
Sounds about right. Add long tube headers and a smaller pulley and you'll probably pick up at least 40 rwhp.
Mark
Old Nov 26, 2005 | 01:19 AM
chriswtx's Avatar
chriswtx
with 273 gears thats probably about right. 118-121mph for the hp you are making and gears you are running. Switching gears will help out some also, so will headers.
Old Nov 26, 2005 | 01:46 AM
brandon1566
what about quater mile times?
Old Nov 26, 2005 | 01:53 AM
chriswtx's Avatar
chriswtx
quater mile times are all about the 60ft and 1/8 times.. Whats you 60ft ant 1/8 times?? You should be able to hit an 11.5-12.3...
Old Nov 26, 2005 | 01:56 AM
brandon1566
my best 60 was 1.898 i believe. 7.677 1/8 11.777 quater at 118mph
If I get tires and stall it up on launch what do you think my car is capable of at 447hp. how would 3:43 gears help my times
Old Nov 26, 2005 | 01:59 AM
brandon1566
i have a grudge match really against this kid in a cobra. I know I can beat him but I cant run consistantly I am either in the high 11s or low 12s. his best run was a 12.1 where he beat me only because his reaction time was 171 to my 536 i ran a 12.03 on that pass I won but he beat me to the line and is tellin everyone he won on video tape. I am running a 20 inch wheel on street tires i know thats my first problem I am buying a set of 17/ 18s and putting nittos on them. thinking about a 3:42 gear. with tires and gears should i be low 11s. I just want to put it to him basically lol
Old Nov 26, 2005 | 02:04 AM
mdhmi's Avatar
mdhmi
You'll pick up 3-5 MPH in the 1/4 by adding long tubes and a smaller pulley.
Mark
chriswtx's Avatar
chriswtx
with tires and gears should i be low 11s, consistant mid 11s for sure. Are you running a DTE trany brace or hardened output shaft? Usually anything below 1.7 60ft or so and things start to break.. How much boost are you running. Headers, a smaller pulley and a tune would get you in the 550rwhp range. There even with 1.8 60fts will get you low 11's... Your hp sounds a little low for an A&A setup.
Old Nov 26, 2005 | 02:14 AM
brandon1566
really motor wise all i have is the A&A blower with the 4 :10 pulley I dont have the tranny brace im trying to find a rear end and hardend shafts right i know with the headers id gain a bit but i dont have 1300 for headers right now i tried getting a smaller pulley but im already pulling 7-10 psi if i go smaler you think the stock bottom end will hold?
Old Nov 26, 2005 | 02:19 AM
chriswtx's Avatar
chriswtx
10psi is the max you want. If you look around you can find used headers for $900. Thats what I payed for my Kooks and 3" x pipe. But when you add headers it will lower your boost a little but add 50rwhp at the same time. Good for 3mph in the 1/4...Also keep your revs under 6500rpm..
Old Nov 26, 2005 | 02:22 AM
chriswtx's Avatar
chriswtx
I also bought my cam, springs, ti retainers and hardened pushrods from forum members. I have like $500 in my cam and valvetrain. Did the install myself. A good blower cam will also add 50-60rwhp...
Old Nov 26, 2005 | 02:27 AM
brandon1566
how many miles on your motor i have 80 000 so i dont know how much life is left in it. the car still runs great tho
Old Nov 26, 2005 | 02:32 AM
chriswtx's Avatar
chriswtx
mine just hit 3800miles With 80000 miles it wouldn't hurt to change your valve springs and timming chain. They are probably pretty tired...
Old Nov 26, 2005 | 02:34 AM
brandon1566
haha wanna trade
Old Nov 26, 2005 | 02:39 AM
brandon1566
so when I lose boost with the headers is it okay to get a smaller pulley to bump it back up to 10 psi
Old Nov 26, 2005 | 02:41 AM
chriswtx's Avatar
chriswtx
You will need to see how much boost you loose first. Without a cam you will probably not lose much. Maybe 1psi...
Old Nov 26, 2005 | 10:46 AM
Busa196's Avatar
Busa196
Your mph and ET's are identical to mine when I had a 2.73 in my car. FYI, I picked up my headers used from a forum member for $600.
If I were you I'd install a 2800 stall converter, 3.42 gears and good set of Drag Radials and then suck the paint off that Slobra. If you can't do all of em at the same time, the first thing you HAVE to do is get rid of that 2.73......My ET's went from 11.8x-11.9x to 11.12 with the change of the carrier alone- and I picked up about 11mph (130)
I'll send you the vid of my car making that 11.12 pass if you want.....Just so happens I was next to a Benz CL600 V-12 twin turbo.....I hurt his feelings
Old Nov 26, 2005 | 09:30 PM
brandon1566
sure id love one
To trapp speeds?
