***Introducing the new PRO Dry kit***
Myself, Scott and Ellis (Speed Secrets) have collaberated on specing this new kit for the LSx. We feel it is a great bargain, using quality parts, and a very complete and ready to go kit, with safety items included ie: fuel press safety switch, NHRA blow down kit (these are normally an extra charge). We chose to use, as the heart of this system, a 400hp PRO Cold Fusion solenoid for durability and future hp upgrading. This is a very clean straight foward install. This kit is also easy to convert to dual stage and/or progressive when ready (these noids can handle progressive). Redundant solenoids are available for those who wish.
Nirous Direct will support all of your technical needs, don't be afraid to e-mail or pm me, with no questions consider unimportant. We will help in anyway needed before, during or after install. We hope to earn your trust and future purchases.
I will personaly be changing out my dual stage 5177 to the better quality PRO Dry. Look for a dual stage version of the PRO Dry at a later date, or can upgrade for you now.
Look for new kits and products to be released in the near future.
***All kits now included a free DVD install video for wet/dry kits and all acc. a industry first.***
PRO Dry kit price $525, with a limited time free bottle blanket (see me for code). Compare the completeness of this kit, and price, to others, and you will see the bargain. Here is a pic.
Thanks Robert
Right or wrong?
And haven't you always been an advocate of dual solenoids for dry kits? Why the change or heart? Or can/should dual solenoids be run here also?
Oh....and just noticed....congrats on the new "Supporting Vendor" status Robert!
Right or wrong?
99% of all nitrous kits wet or dry offer a single solenoid set up for the nitrous.
Even in a wet kit with a single noid on the fuel side and a single on the nitrous side, if the nitrous noid failed you think you're safe, that would be your arguement? Well fuel puddling in your intake then become the problem.
There is no perfect solution to anything and anyone in the business with real knowledge could point out faults to any system or setup.
Nitrous solenoids RARELY fail and if they do it's due to debris or being improperly wired. Debris can be solved with a high quality nitrous filter.
Dual noids is a decent idea if you want real redundancy, but it is not needed.
I personally run 225HP on an 8.1 and do not run dual noids in a wet set up
With a dry setup like this if it fails it's most likely not going to open, and that's not a problem.
Robert
Robert
