A&A Vortech Kit Install/Dyno
Old Dec 7, 2005 | 10:43 AM
mwbmd11's Avatar
mwbmd11
Default A&A Vortech Kit Install/Dyno
Got the kit completed and took it to Dallas to LG for a tune. With a conservative tune 516.7 RWHp and 464.4 Torque. I have a stock 2000 Coupe with the exception of a Borla cat back and off road x-pipe. I'm very pleased with the whole setup. I'd post the dyno sheet but I can't seem to get a good picture. If your interested I'll email you the pictures. The boost is right at 8#s with a 3.8 pulley. No belt issues at all. Kit looks great and runs WOW!!!!!!!!!!!! Power comes on at about 2500 rpms 360#s torque at 2600 goes thru 400#s at 3300 and maxes out at about 4700. The HP line is 180hp at 2500 rpms and is almost a perfectly straight line up to a max of 516.7hp at 6300 RPM. Ok, mabe I should just round up to 517 it sounds better. Thanks to the guys at A&A for the phone help during the install and the Guys LG for a great tune. YES!!!!!
Old Dec 7, 2005 | 10:45 AM
JeremyMSG's Avatar
JeremyMSG
Sounds like another satisfied customer
Old Dec 7, 2005 | 11:18 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Those are some good and safe numbers for a stocker my the FI be with you and congrlautions
Old Dec 7, 2005 | 11:19 AM
elric's Avatar
elric
Congrats!
Old Dec 7, 2005 | 01:19 PM
7LitreC5's Avatar
7LitreC5
Great numbers!
How noisy is the Vortech and the BOV? Are you running an S-Trim or T-Trim head unit?
Old Dec 7, 2005 | 01:26 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Send me the pic's Thanks.
Old Dec 7, 2005 | 02:33 PM
RAO-3's Avatar
RAO-3
Congratulations and enjoy the added power!
Old Dec 7, 2005 | 03:00 PM
mwbmd11's Avatar
mwbmd11
The Vortech unit just sounds like a moderate whistle at Idle. That sound goes away as you add throttle. As for the BOV you have to get on it hard and let off quick at 8 psi to hear the BOV. Pretty loud when it does activate. About like an air compressor blowing a hose off. The unit is an S-Trim.
Old Dec 7, 2005 | 03:55 PM
7LitreC5's Avatar
7LitreC5
Ok, thanks. That is what I wnated to hear.
Old Dec 7, 2005 | 04:07 PM
Sportsdude's Avatar
Sportsdude
Congrats and nice numbers
Old Dec 7, 2005 | 10:58 PM
Steve'01's Avatar
Steve'01
Sounds like a good safe tune, once you go forged you can turn up the boost and off you go.
I was just thinking after I posted, I wonder what the difference is between 500 and 600 and 700 RWHP besides some spinning tires.
Old Dec 8, 2005 | 03:08 PM
TM-Z06's Avatar
TM-Z06
Hmmm.....moderate whistle? Is that the V1 or V2 head unit? (The V2 is pretty silent, and the V1 sounds like rocks grinding & a whistle)
Old Dec 8, 2005 | 08:20 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Nice numbers, makes me look forward to gettin my kit in. I will have an otherwise stock 2000 model.
Old Dec 9, 2005 | 09:09 AM
elric's Avatar
elric
I *think* the whistle is coming from the BOV at idle or near 1k rpm rather then the head unit, but I may be mistaken. I have the same kit which uses the V2 S-Trim and the Vortech Race BOV.
Old Dec 12, 2005 | 03:50 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Did you leave the stock valve springs on yours?
Did you loctite the cam bolts?
Old Dec 12, 2005 | 10:50 PM
mwbmd11's Avatar
mwbmd11
No heads and cam on this car. Engine internals are stock.
Old Dec 14, 2005 | 08:26 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
To A&A Vortech Kit Install/Dyno
Old Dec 14, 2005 | 08:46 PM
Watch22's Avatar
Watch22
Nice numbers! I'm getting the A&A kit this winter. I also heard that its a good idea to locktite the cam bolts and change the springs.
Old Dec 14, 2005 | 08:51 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
I think I have just decided to throw the LS6 cam and valve springs in and get the ARP cam bolts and loctite
Old Dec 14, 2005 | 08:54 PM
elric's Avatar
elric
I almost did the same, but ended up sticking with my stock cam/springs/valve. Did not loctite either (hopefully it wont bite me in the butt) but for some reason, when I was doing my searches the z06's seemed to have that problem with the cam bolts backing out and not the ls1's. Unsure why.
