LQ9 72cc unmilled heads : anyone have a pair for sale?
Supporting Tuner
Yes, yes, I know, I could post this in the Parts section but since these heads are almost exclusively used in FI, I thought I would ask you guys and gals first. :bb
Hoping to hit 9.0:1 STR with Cometic gaskets on a LS2. Piston cc and brand are unknown at this time - any suggestions? Needs to withstand 15+psi for long periods of time (road race) and not have to be changed every xxxx thousands of miles.
Any help would be appreciated. And go easy on me - I'm new to this LSx thingie
EG
EG
Supporting Tuner
Originally Posted by TURBO VET
I have a set that are #317 castings for $350 shipped. They are used but in good shape. PM me if interested.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
EG, I was thinking of going to the ETP's on my car, I have a well above average set on my vert now if your looking for something wild to put on there. (not as cheap as the the other set tho).
Sent you a PM, I have a brand new set that are completely assembled.
I would take $550 for them shipped, that is what I have into them.
If anyone is interested.. let me know.
Nick
Nick
Supporting Tuner
I sent you a PM.
Supporting Tuner
Nick
Nick
Supporting Tuner
Heads purchased! Thanks everyone
Love this Forum !
EG
Love this Forum !
EG
Supporting Tuner
Any suggestion on pistons? <see post #1 for criteria>
JE makes an off the shelf piston... part number 221178
It is a 4.060 bore, for a 4 inch stroke with a 6.125 rod. With the 317 heads and an off the shelf GM gasket that would put you at 8.9:1 with a 0 decked block.
Hope that helps!!!
EDIT: I emailed you the page from their catalog and the compression ratio calculations. These are the pistons I was going to use if I went to an LS2 block. Just cannot justify the extra jack when I can make up for it with the twist on the boost controller...
Supporting Tuner
Yes...
Hope that helps!!!
Hope that helps!!!
Stephen
Thanks Nick. I'll be using a 4.100 inch stroker in my new LS2 for 412ci. Rods are still up in the air but probably Lunati Pro/Mod rods. Will the JE work with that long stroke or do I need to get shorter rods?
Stephen
Stephen
You should certainly source everything together with a set idea of what your goals are. You have to pick a piston based on the heads you are using (which you have now) and then pick a rod that is compatible with the piston and crank you are going to use.
I think I remember reading more than one place that FI motors respond better to bore than to stroke as well. The guys at ECS can tell you what to use...
Supporting Tuner
I struggling with the math here (and I have my post grad degree in Math ) but how can a 4.000 inch stroke and a 4.000 inch bore equal 414 cubic inches? The numbers work out to 402ci.... or am I missing something?
The piston I showed you is a 4.060 bore... back to the calculator.
Or better yet.. use this:
http://www.c5frc.com/calculators/Com...Calculator.htm
Quick and dirty.
Supporting Tuner
Doh! Just stupid, I guess
Supporting Tuner
I didn't realize you could bore the LS2 (or LS1/LS6) .060 inches over. I thought they had to be sleeved for anything over .005 inches?????
<work with me here, I'm new to this LSx stuff>
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
WHat ever the answer to the issue(s) that BLOWN Z raises i do agree that you should stick with a 4.00 inch crank as those have proven to be the MOST RELIABLE and best performers with LSX motors. I had a 4.125 brand new CALLIES CRANK fail in a 427 iron block LSX motor i had with a 4.060 overbore and the the crank failed after only 4K miles on it as the crank welds and reluctor wheel broke on the piece of sh it 4.125 forged BRAND NEW CRANK!!!!
My engine builder (very reputable here) told me that the crank failed because the geometry of the motor was off b/c the 4.125 stroke was to much for the iron 4.060 overbore. They then immediatley recommend that i go to a 4 inch crank and that is what i did with 0 issues after that.
I would go with the safe and battled tested big cubed crank for proven reliability and performance that being the 4.00 crank. TRUST ME 10 more cid is not going to matter with the MEGA POWER your ECS NOVI Powered LS2 motor is going to be making!!!!!! THe power will be there regardless and I would really focus on longevity, durability and engine life, especially since this is going to be an everyday driver
BEST OF LUCK!!!!!!!
BEST OF LUCK!!!!!!!
St. Jude Donor '06
Originally Posted by zeevette
I think I remember reading the maximum overbore on a LS2 is .030.
