Luk Pro Gold?
Old Dec 31, 2005 | 08:00 PM
whitelite's Avatar
whitelite
Default Luk Pro Gold?
Anyone have experience with this clutch?
Old Dec 31, 2005 | 08:35 PM
DDSLT5's Avatar
DDSLT5
Yep - had one on my car. On low boost, 10 psi, 585 rwhp, 570 rwtq, it performed well. Pedal effort is about the same as stock (very friendly), take-up is nice and easy too. On high boost, the clutch still held the power (650 rwhp), but the clutch would heat up, and then you'd lose the pedal - and you wouldn't be able to shift out of that gear until it cooled - so now I have the exceedy twin disc which is a monsterous effort clutch with no slipping allowed. The Luk Pro Gold is a fabulous clutch as long as you're below 600 rwhp/tq.
Old Jan 1, 2006 | 06:04 AM
tt427pacecar's Avatar
tt427pacecar
St. Jude Donor '05-'06-'07
Had one in my LPE twin turbo GTO (510 RWHP, 500 RWTQ). Great pedal feel, but it slipped way to often for my taste.
Going to try the Textralia (Aussie) clutch next.
Trying to avoid using the Exedy twin (due to the pedal force required).
Old Jan 1, 2006 | 09:40 AM
RoadRebel's Avatar
RoadRebel
Luk pro clutch is the Stock Z06 Clutch disc and pressure plate with Fidanza aluminum flywheel.
Phil
Old Jan 1, 2006 | 07:01 PM
whitelite's Avatar
whitelite
Phil
Hi Phil,
Since you will probably be getting the car this winter for the clutch install and other things we talked about, I'll be calling you about this too!
I guess if this is the case then you would recommend the New Z06 clutch over this one.....
Old Jan 1, 2006 | 10:15 PM
RoadRebel's Avatar
RoadRebel
Originally Posted by whitelite
Hi Phil,
Haha, Yea I am installing another LS7 Clutch and a maggie for a guy from the other side of the state. If you want to see how it feels see if you can swing to this side of the world next weekend. The LS7 is a real tough clutch to beat for the "tweener" power guys.
Phil
Old Jan 1, 2006 | 11:56 PM
Skunkworks's Avatar
Skunkworks
Phil
Tweener??? what RWHP
Mikr
Old Jan 2, 2006 | 07:15 AM
jkz06's Avatar
jkz06
My car made about 490 at the wheels, never saw the track, and my Luk only lasted 9 months. I would go with something else.
Old Jan 3, 2006 | 08:51 AM
whitelite's Avatar
whitelite
Mikr
480RWHP/504RWTQ
Old Jan 3, 2006 | 10:20 AM
ScottN's Avatar
ScottN
St. Jude Donor '05
I had the LUK Pro Gold installed with my head/cam package. It was perfect with that setup. Pedal action feels pretty much like stock...maybe 10% stiffer. But, now that I have switched to a TT setup, the clutch is not up to the the task but it was never advertised to hold the power I'm runnning now. I think the Pro Gold is rated to 575 at the flywheel.
I'll run the LUK until it craps out then go to a RPS, Textralia, or Cartek clutch.
Old Jan 10, 2006 | 11:24 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
I have a LUK Pro gold and its been great for my setup. Slightly heavier than
stock and no more sticking from 3rd to 4th like my stock clutch.
Old Jan 14, 2006 | 01:18 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
You have to adjust the LUK to it's highest setting. It's a great clutch once it's adjusted. I use them all the time.
BTW: It's made by the same company as the Z06 clutch but the lining is of a different material.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Jan 14, 2006 | 07:20 AM
Warp Factor's Avatar
Warp Factor
Andy;
Will either the LUK or the C6 Z06 clutch hold up OK to 600 horse? Occasional drag strip use?
Which of the two is better? What do you mean by "adjust to it's highest setting?
Any experience yet with Cartek?
Thanks.
Old Jan 14, 2006 | 12:00 PM
chriswtx's Avatar
chriswtx
Old Jan 16, 2006 | 09:33 AM
Warp Factor
ttt
Old Jan 16, 2006 | 09:43 AM
RoadRebel's Avatar
RoadRebel
Originally Posted by Warp Factor
Andy;
Thanks.
The LUK is the same plate as the stock Z06 and has 3 slide tabs that adjust the preload on the plate. Even adjusted to full load I dont see them holding up to 600hp regularly.
Phil
Old Jan 16, 2006 | 11:34 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I've ben running one for over a year. The only isue that I found was when I slipped it. Do not do this...that's the weakness. If you're into drag racing you may also want to look at something else for over 600rwhp apps but for street use and road track use it'll work fine--just my experience.
Old Jan 17, 2006 | 12:34 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Dave,
You are going to want to go with Cartek Clutch. Best proven single, great price.
Rick at Synergy sells/install these like hotcakes.
Brent
To Luk Pro Gold?
