NO2 and compression
Old Jan 7, 2006 | 01:07 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default NO2 and compression
looks at my sig. I was thinking of putting NO2 on my car when the AFR heads get bolted on. Ill have just under 11:01 compression and I was wondering if that is to much compression for a 100 shot. Ill also be putting in a new clutch at the same time
what's your thoughts?
Old Jan 7, 2006 | 01:33 PM
kumar75150's Avatar
kumar75150
nitrous loves compression
the higher your compression, the better the nitrous will respond
Old Jan 7, 2006 | 01:37 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I agree, some of the nitrous racers run like 14.1 and 15.1. that's baby compression for a n2o hit, don't worry it's fine.
Robert
Old Jan 7, 2006 | 02:31 PM
phils C5 vette
how about blowing a head gasket issue. Ill be using the stock GM MLS gasket. I think a closer estimation of my compression is 10.8:1
Old Jan 7, 2006 | 05:00 PM
StreetRacingGuy's Avatar
StreetRacingGuy
you will be fine....pump gas, 11-1 CR and 150 shot will be perfect, even without timing retard (more than likely, will still want to check for KR on wideband). At most you will need a timing tuner to pull out 2 degrees or so IF you get KR (which you probably wont). Stock MLS gaskets are very very nice, don't worry. Go spray.
SRG
Old Jan 7, 2006 | 05:25 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Great information...this is why I love this forum!
Old Jan 7, 2006 | 07:36 PM
cheemsaf's Avatar
cheemsaf
SRG
I used to run a 150 shot with no probs with timing, gaskets, or any thing else. Don't forget...colder plugs (I ran NGK TR6s). Good Luck!
Old Jan 7, 2006 | 09:16 PM
sqeznbi's Avatar
sqeznbi
What you want to avoid is using nitrous at too low of rpm with higher compression. Use a tps switch or rpm switch , mines set at 3400 but im blown too so im not sure were you want to set it ,generally above 3000rpm. A couple of coworkers of mine have cobras and they changed the pullies which gave them more boost but cost them some head gaskets actually cost one of them the whole top end , i guess when the heads lifte the cam drive broke. You will want to run coler plugs and retard your timing a degree or two. I got sick of ordering those tr6,s and found that ac delco R42lts plugs work great.
Old Jan 8, 2006 | 02:09 AM
Robert56@RNS
Collections Hold
As long as you have stock timing (none added) 95% of the time no timing pull is needed on 150hp hit or less. Scaning for knock retard is a good idea to ultimately check timing. Use a wideband for checking a/f ratio which is also a good idea for safety. Use the highest octane fuel you can get ie: 92/93/94. Colder plugs like the tr6 gapped at .035 is a good idea as the stockers can become blow torches because of the narrow grounding strap (get red hot). Your comp. is great for a street/strip car, no worries. Good luck, and have fun. If you have any tech questions feel free to pm me.
Robert
Old Jan 8, 2006 | 07:11 AM
phils C5 vette
how long does a 100 shot 10 pound bottle last ?
I guess I should ask how many minutes the bottle last
I would use it from 3200 to 6500 RPM range with a window
Old Jan 8, 2006 | 09:49 PM
phils C5 vette
ttt
To NO2 and compression
