Procharger Belt Walking Problem
Sad story...just had a D-1SC ATI Procharger installed and everything seemed good to go (dynoed @ 545RWHP/463ftlbtorque !!!), and I got on it hard and heard a POP!
Popped the hood and the sound insulation on the bottom side of the hood was shredded where the serpentine belt would have hit it. The belt had walked off, but by only one rib, and was now functioning fine on 5 of 6 ribs....weird or what? It was no longer walking off the pulley. Since then, a new belt has been installed with the same problem. The tensioner & pulleys have been messed with trying to get the belt to not "walk". No luck thus far. What is weird is when the SC is turned backwards, the belt walks back on to the pulley.
In summary: it's working fine with only 5 of 6 ribs, it walks off when the car is on, and when the SC is turned backwards, it walks back up to where it should be and then remains in the proper position.
Anyone out there with a clue as to what can be done?
Mark
I found my pulleys were off by an entire rib. This caused the belt to shred after less than 800 miles. Use the Gates Laser Alignment tool .... I found one for about $120.00. I made all new shoulder bushings to correct the misalignment.
Brian
BTW -BlackMagicC5...viper driver, by chance?
How about you?
the D1 that is on my car was put in in august - and apparently that's when the new "design" came out - so needless to say, my car's been tied up for over 2 months now with no word from ANYONE as to what's happening!
How about you?
Togo- YES, it was ordered from them in October - a true ATI Procharger. Procharger did not know what was going on and seemed clueless as to why this was happening. What do you mean "normal" tolerance of pulling out (sts)? This does not sound good. It seems to be riding fine right now. It has ~ 100 + miles of not so easy driving on it since it was "fixed".
they said they replace the seals and a few other thing - which i'll find out tomorrow when i go visit my car. i suggest calling them and getting started - as they are SLOW to get work done - they got mine on dec. 20 and they just sent it back to us jan 11 - perhaps it had to do with the 2 holidays in there - but i'll never know!
good luck to you and i'll update if/when something comes up - if we get it back and it still shreds, you can bet they're gonna catch he!! due to the fact that it cost me $44 to ship it to them, PLUS the removal and reinstallation fees! so we'll see what happens
***EDIT*** forgot to mention that ATI is in KANSAS - so check your time zone difference before calling - oh, and also, James is kinda bad about returning messages, so you may have to call him more than once before he returns a call to you!
wondered what they said
The belt would only move off "track" when the car was cranked...that was what got the belt moving off the pulley. I guess they called Procharger and told them the story, and they mailed off a new pulley and tensioner. They mailed off a pulley with a different lip on it and said that now when they crank the car, the belt still moves, but it bumps against the lip and moves back to where it should be. After the cranking is done, the belt rides normal at all RPMs. They said they've never heard of this happening before - "cranking causing the belt to walk off". I think the tensioner that they installed also helped. Heck, I'm happy, the belt after about 25-35 cranks has no wear on it, no fraying, and thank God, no walking off the job problems! THANKS XTREME!i wonder if that will be resolving my problem too?
they replaced the idler pulley on the tensioner and actually rebuilt my supercharger.
time will tell!
thanks for the update
to clarify - did you get a new crank pulley also?
or was it just the idler pulley on the tensioner that has the new "lip"?
