Nos MSD Window Switch?
Old Jan 14, 2006 | 10:52 PM
gogo4's Avatar
gogo4
Default Nos MSD Window Switch?
How can I tell if this works ? I have compleated the wiring and installation but when my car is given power ...not started and if I hit the throtle with the nos activation switch on... i still hear the solenoids click! They are only really suppposed to hit at 3k right?
Old Jan 14, 2006 | 11:07 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Yep, if set at 3000rpm then noids should not click till then. I would recheck wiring, as something may be amiss. Is it a digital, if so, many have been having problems.
Robert
Old Jan 14, 2006 | 11:16 PM
gogo4's Avatar
gogo4
hmm it is not a digital one.
so I should not get any clicks I wonder whats going on.
Old Jan 15, 2006 | 12:39 AM
Robert56@RNS
Collections Hold
Also, shouldn't be clicking unless a wot? re check wiring.
robert
Old Jan 15, 2006 | 06:00 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Do you have it set correctly to recognize the coil pack ignition? IIRC the digital one the instructions were wrong on setting the box for the right ignition (I know its not the digitial one...worth a call to MSD).
Not sure as I have not installed one yet, but I remember reading that Xtrooper had to select I think 4 when the instructions said to select 1 when configuring the window switch (or it was vice versa).
Found his post...
Xtrooper said...
I went out and bought an MSD digital and wired it up last night. Tested it today in the garage and on the street and it's working 100%!
One note: Don't follow the instructions and use Cylinder Mode 1 for the LS1 motor. It doesn't work. Use the 4 Cylinder mode as we normally do and it'll work fine.
Beer
Old Jan 15, 2006 | 08:31 AM
wyndzer's Avatar
wyndzer
Beer
Same problem I had at first with mine, works like a charm in 4 cyl. mode. Go figure
Old Jan 15, 2006 | 04:16 PM
gogo4's Avatar
gogo4
yeah I had it set on 4 cyl mode... too.
One question does the relay that it hooks up to have to be grounded individually?
Or do I not ground the relay but ground out the msd and thats maybe what sets off the click right?
The wiring diagrams first show to ground out the relay too..then ground out the msd also! I am puzzled will go mess with it today again.
Old Jan 15, 2006 | 10:59 PM
gogo4's Avatar
gogo4
got it!
Old Apr 15, 2006 | 02:13 PM
Vette-Dream's Avatar
Vette-Dream
what was the solution to grounding it?
Old Apr 17, 2006 | 08:28 PM
Fastbasser's Avatar
Fastbasser
I see you fixed it. Mine came out of storage and the same thing is happening. Solinoid clicking w/o being at the rpm I set) What did you do to fix it??
Thanks in advance..
Old Apr 18, 2006 | 07:39 PM
Fastbasser's Avatar
Fastbasser
TTT. Anyone know how this was fixed?
To Nos MSD Window Switch?
