MSD digital Window switch help?!
Old Jan 17, 2006 | 07:53 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default MSD digital Window switch help?!
Hey guys, i helped a buddy of mine install a nytrex sytem into his car. I've got it wired up with an arming and WOT throttle control the switched power to the relay. I tested this with a meter and this seems to be working correctly.
I checked the always on power to the relay and it's good. I checked the connection of the relay to the solenoids, that's good.
The issue i keep getting hung up on is this MSD window switch. I set the window switch to 4cyl, and it gives me the proper reading on its display.
When i check the "switched ground" <yellow wire> I seem to always have at least 9volts <higher when the car is on>. I can't seem to detect an opening of the ground.
Even though my volt meter can detect a ground coming through the window switch, it doesn't seem to open the solenoids.
Do you guys have any advice for testing the window switch? Any tricks that i may have missed besides the 4cylinder set up?
Any help would be appreciated.
Thanks,
Chris Wetmore
Old Jan 18, 2006 | 12:24 PM
Stangkiller
Ttt
Old Jan 18, 2006 | 01:38 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Find cheap test light. Connect one end to a 12 volt fused source. Connect the ground ed to the yellow lead from the MSD. Adjust the window to operate between 1300-2000 rpms. Then by blipping the throttle in nuetral (by hand) and activating the microswitch by hand, the test light should light when only in the rpm window.
Old Jan 18, 2006 | 01:58 PM
Stangkiller
Awesome, will do that, tomorrow afternoon now...if this does not work. does that mean, the MSD switch could be bad? Or if i had wiring issues, could the window appear to be on and working, and just not grounding properly?
Old Jan 18, 2006 | 02:21 PM
402Sam's Avatar
402Sam
Is this the digital window switch. If so I heard alot of people having issues with them. I went with the basic pill window switch. Alot easier to use IMO..
Old Jan 18, 2006 | 02:36 PM
ksaieg78's Avatar
ksaieg78
i had a similar problem on my car and over all was not happy with the window switch because if there is a problem the nos will continue to spray so long as you are in that rpm window.
i now have wired both a wide open switch (runs off voltage from throttle motor) with the window switch. if you wanted to
you could just run the wide open switch. (nitrous express is the only one that makes a wide open switch for the c5's)
Old Jan 18, 2006 | 05:27 PM
Stangkiller
Yes, this is a digital msd window switch
Making your own WOT switch it pretty easy, with a micro switch.
This system is set up with a arming switch and WOT supplying the switched power to the relay. The Window switch supplies the ground to the relay. Then of course the relay has a constant power source, and then connect's to the power on the solenoids. The solenoids are then grounded.
I can't seem to get the system to fire. I pulled the relay off last night, and with a volt meter tested the 4 different wires. I put power to the solenoids, they fired. I recieved power from the arming and wot switch. Then I checked the power from the always on, and the ground on goign to the window switch. it seemed as though i always had a little bit of ground. which really confuses me as to why the system isn't firing.
Thursday night i'm going to try the light, and probably call MSD for some tech help.
Chris
Old Jan 18, 2006 | 11:16 PM
JoeyG's Avatar
JoeyG
I never tested the MSD for any kind of leakage. The way you described you system wiring, sounds correct in operation. One thing to think of with digital meters, is they load circuits differently than an actual load would. try the test light and see what it does. If it doesn't work, then call MSD. By the way, I've never had a problem with mine.
To MSD digital Window switch help?!
