nitrous
Old Jan 18, 2006 | 12:23 PM
666's Avatar
666
Default nitrous
can a stock motor take a 150 shot direct port?????
Old Jan 18, 2006 | 02:54 PM
ksaieg78's Avatar
ksaieg78
yes, i would reccomend a bigger fuel pump
just wondering what type of kit do you have
i have a n/x direct port kit and am very happy with it althogh
my clutch did not like it
Old Jan 18, 2006 | 03:55 PM
666's Avatar
666
im looking at a Nos kit- did you burn your clutch up?-is 100 hp shot more realistic?
Old Jan 18, 2006 | 04:32 PM
402Sam's Avatar
402Sam
Runnin a 200 shot here. Just run some good gas (100oct) and retard some timing. Also change out the plugs to some TR-6 NGK. Stock motor and fuel will hold a 150 no problem as long as you change the plugs. DO NOT SPRAY ON THE STOCK PLUGS!!!!!
Old Jan 18, 2006 | 09:45 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
No problem, 200 last year, and going for 300hp on a triple stage with final stage on progressive, this year. We have a nice PRO EFI DP just added to our line up. If you have any questions about this kit or any other let me know I would be glad to help.
Robert
Old Jan 18, 2006 | 10:09 PM
666's Avatar
666
wow! this site is awesome-so many people -and vendors willing to help-awesome...simply awesome-thanks so much!!!
Old Jan 19, 2006 | 09:27 AM
bobby777's Avatar
bobby777
Give it a 250 shot--let us know what happens--
Old Jan 19, 2006 | 09:31 AM
User 81424's Avatar
User 81424
And I the friendly mod moved your post to the N2O section for even better response.
Old Jan 19, 2006 | 05:31 PM
z06pdq's Avatar
z06pdq
From: Only in America can you get paid that much money for crying --the state of Texico
no problem w/150 shot but, unless you're going to a larger shot later on direct port is a waste of money [expensive] & if you go more than 150 you will have to split it up [stages] because at those power #'s you are playing w/fire on a stock bottom end.now, if you plan to forge the bottom & shoot a big shot [200-300] then by all means go w/a d/p setup.
To nitrous
